AdBlock Warning
b1g_dav3
Short-Shift Gear Stick - What's Involved?
15 posts in this topic
Hey, just wondering how difficult a short-shift stick is to put in?
http://www.mountunestore.com/Product/Short-Throw-Shifter
That one in particular, being a lease car I need to ninja-install something like this, and I'm not overly mechanicy, so how easy would it be to put in and what's involved?
Thanks.
Well ordering one I think, so if anyone can help it'd be appreciated!
Let me know what's involved in the mod, I'm looking at a week until I can order one :P
It's quite straight forward..
Removal: remove gear knob and gaiter, Remove side panels and top section of the center console, disconnect the selection cables, undo 4 nuts, remove.
Fitting: do the above in reverse
I have mine already, and it will be installed at the weekend, full install instructions in the box. :D
Really hate the gear-selector on the Fez, it's a big spongey and meh. This is a much needed part :P
£170 all in! Pfffttt bit expensive lol.....
Nice mod though get fitted pics up lads
I'm doing without the Mountune badged gaiter, I just want the function, plus lease car so ninja-fitting :P
Right, well mine has been installed, and feels fantastic, shift is nice and smooth.
Full Shot
Side Shot
Although, if anyone does fit this there are a couple of things the Mountune instructions do not advise you to do.
So I will fill in some advisory gaps in instructions:
1. When removing the gaiter and surround pull up from the furthest point else you will end up snapping retaining lugs:
2. Remove the section just below the gaiter surround also, as this will make removing/refitting the side panels easier, again pulling from the furthest point helps
Remembering to disconnect the 12v and aux/usb connector:
3. After removing the two Torx (Mountune say it's T27, I found mine were T30) in Step6, it's advised the also remove the rear 2 plastic screws seen here (one on either side):
And remove the between seats center console completely, leaving you with a lot more room to play, as you will need it:
nice info still waiting for mine as i ordered the whole kit
mines being dispatched today will post some pics once fitted
short shifter great smooth changes works very well
Thanks ,Helped me a bit to do mine ... Took me 30min with the advise,so I'm happy with that :) feels great ... I'm now getting used to going lower with my hand to change gears ... Whoop whooop
i ordered the steeda kit withthe alloy mountings aswell. reduces gear throw more than the mountune part and is amazing quality aswell. i looked at the mountune part before i ordered and was not as impressed as i was with the steeda part.
bit more expensive but worththe extra
Oi
Is that you Reaper???
