Towing Angle?
towbar s-max angle
4 replies to this topic
#1 pmsansom
pmsansom
    Newbie
  • Pip
  • 1 posts
  • Name: Pete
  • Ford Model: S-max
  • Year: 2007
Posted 25 April 2012 - 03:40 PM
Hi guys,
I had a towbar fitted yesterday on my 57 plate ford s-max. Hooked my trailer up and was just a bit concernd about the towing angle. (see attached pic).
I've no previous experience of towbars or trailers/towing so just wondered what the consensus was.
Is this ok? Can/should anything be changed?
Pete
#2 pragmatix
pragmatix
  • 344 posts
  • Name: Pete
  • Ford Model: Mondea 2Ltr Tdci Ghia X Estate
  • Year: 2002
Posted 25 April 2012 - 07:55 PM
In a ideal world the hitch should be level, can the ball be dropped some tow bars have multiple positions for the ball
#3 jeebowhite
jeebowhite
  • 4,266 posts
  • Name: James
  • Ford Model: Focus CMAX 1.6 CVT TDCI
  • Year: 2005
Posted 26 April 2012 - 01:24 PM
Ideally it could do with being lower, however as long as its secure, then there should be no real cause for concern.
#4 DaveD
DaveD
  • 147 posts
  • Name: David
  • Ford Model: Ford Ka Edge
  • Year: 2012
Posted 26 April 2012 - 03:23 PM
Hi I used to tow a caravan. Your trailer does look a bit too high. You can purchase a lowering plate from most caravan accessory shops. I arranged my vans to be slightly down hill on the tow ball. I like a bit of weight on the tow ball about as much as a heavy suitcase but read what your car manual specifies. Remember to keep an eye on your speed and watch for any 'snaking'.
#5 dave h
dave h
  • 52 posts
  • Name: David
  • Ford Model: Ford Maverick 2.7 Tdi GLS
  • Year: 1998
Posted 26 April 2012 - 04:33 PM
Hi the tow ball height should be between 350mm to 420mm ( 13.8" to 16.6" ) measured from the ground to the centre of the ball with the car fully laden. Be carefull with drop plates as all new towbars are of a specific design and will weaken it if a drop plate is fitted, check with your towbar manufacturer first. Hope this is of some help. Dave
