How To Remove A Standard Ford Stereo
#1
Posted 28 April 2012 - 02:51 PM
#2
Posted 28 April 2012 - 02:54 PM
#3
Posted 28 April 2012 - 02:57 PM
#4
Posted 28 April 2012 - 03:04 PM
#5
Posted 28 April 2012 - 03:12 PM
Not sure what you mean by universal?
You could be cheeky and bowl up at a car audio store and ask if they can pop your stereo for you.
You only need the tools to remove not to refit.
#6
Posted 28 April 2012 - 03:17 PM
#7
Posted 28 April 2012 - 03:19 PM
if you have a hallfords store near you.
#8
Posted 28 April 2012 - 03:20 PM
#9
Posted 28 April 2012 - 04:07 PM
Then yes.
You need 4, one for each corner.
#10
Posted 28 April 2012 - 04:34 PM
#11
Posted 28 April 2012 - 04:36 PM
#12
Posted 28 April 2012 - 05:45 PM
They will clip into place and then you angle the keys out to the edges of the radio to disengage the clips on the radio.
The keys will only come out when the radio is fully removed as they hook onto the clips, just use a fingernail or a small screwdriver to lift the clips clear of the notch.
Quadlock has a hinged loop which you need to piviot up to release.
There is a small lock catch you need to disengage to release the loop.
#13
Posted 29 April 2012 - 08:33 PM
#14
Posted 29 April 2012 - 08:38 PM
#15
Posted 30 April 2012 - 04:31 AM
I seem to remember someone on this or another Ford forum had problems with an adaptor and later found out is was a Vauxhall (spit) one, the wires were all wrong but the connector was the same.
Also if you intend to keep your steering column remote active an adaptor unit is required too.
