kirst88
Alloy Centre Caps
Do you have wheels on or off? I've only done it when they're off and just poked it from behind.
So I can put my dmbs on :)
The dmbs are just overlays that stick on top of the existing centre caps, there is no need to remove them.
Be sure to clean the centre caps thoroughly first & it helps to warm the overlays with a hairdryer first to help them stick better.
Just be careful to centre them correctly before applying pressure as this can be quite tricky.
You should end up with something like this :)
I stuck them on as above and they fell off after a week so had to get new ones :(
Had mine on for 2 years now, still looking good & have been washed many times with no problems.
Maybe you got a dodgy batch, did you contact dmb for replacements?
