My Cars "features" According To Etis.
24 replies to this topic
#16 Mike77
Mike77
  • True Ford Enthusiast
  • 959 posts
  • Name: Mike
  • Ford Model: Fiesta 1.6 TDCI Titanium
Posted 17 May 2012 - 02:57 AM
Thanks yep I think your right. I dont have Steering menu option,so must be stiffer springs "sport suspension".
Any idea which is better? electro hydraulic steering or stiffer springs "sports suspension"? I guess it does not make much difference?
Steering and suspension are two totally different things, stiffer springs just give a firmer ride, and with the right setup can aid with road handling.... The hydro steering gives 3 different settings for firmness of turning the wheel. As stated earlier the sport mode makes the steering heavier, as when traveling at speed this would be better, making the car feel firmer and less twitchy. Weather hydro steering or stiffer springs, they all seem pointless to me unless its in a ST model, and even then if your within the speed limits, you'd very rarely need them.
Have something to contribute?
#17 artscot79
artscot79
  • PipPipPipPipPip
  • 7,931 posts
  • Name: arthur
  • Year: 2006
Posted 17 May 2012 - 06:31 AM
ide disagree having driven an lx model it has standard springs very bouncy in the corners the zetec stiffer springs arent so you can take corners with more speed and confidence knowing it wont bounce over the road at the slightest bump mid bend, the car is more planted less bounce and more confident .until you drive both right after each other you dont realise the difference it makes
#18 DJ_Andy_M
DJ_Andy_M
  • Budding Enthusiast
  • 148 posts
  • Name: Andy
  • Ford Model: Ford Focus MK2.5 Facelift Zetec
Posted 17 May 2012 - 01:26 PM
I cant find any setting like that in the menu only can see ESP. Do you know where it is? Is your car pre 2010? Mine is 2010.
May be why mine says standard suspension rather than handling? Seems cheeky if i'm right.
Make sure you're stationary when you do it too otherwise you won't see it ;)
#19 r4963
r4963
    Member
  • New Member
  • PipPip
  • 10 posts
  • Name: Dave
  • Ford Model: Focus Zetec
Posted 19 May 2012 - 04:46 PM
I definatley dont have the steering option. So i dont have the hydro steering i guess? I cant work out what part of etis refers to this for cars that do?
As far as i am aware standard suspension on the zetec is stiffer springs. Listed as "standard" suspension on etis. Although the titaniums also have "standard" suspension as per etis but this means softer sprung because its a titanium?
Though that still makes me wonder what "handling" suspension means on etis? Because some zetecs seem yo have this listed
#20 Sliveredge
Sliveredge
  • 95 posts
  • Name: Peter
  • Ford Model: B-Max 1.0 125 titanium
  • Year: 2014
Posted 28 May 2012 - 10:59 PM
handling suspension is part of the sports pack that ford done along with tints and the next size up alloys, it was stiffer and slightly lower than the normal zetec ones
The steering settings you will only see if you car has electronic steering I believe it was only fitted to 1.8 upward petrols and diesel's no matter what trim level you had. If you have power steering fluid under the bonnet you dont have electronic powered steerin.
The auto lights seam to be on every car on etis i believe its cause all the cars are wired but no senors and not enabled. it will say "With Automatic Headlamp Control" if you have auto head lights.
#21 jg321
jg321
  • 207 posts
  • Name: Jon
  • Ford Model: Focus Mk 2.5 1.6 TDCi Zetec
Posted 29 May 2012 - 11:56 AM
Mine is a Zetec; no sport pack, and according to Etis has 'Handling suspension'. Have to say, one of the first things I thought when I drove the Focus (have only ever driven Zetecs) is that it seemed to have pretty firm handling, which took a bit of getting used to, but now anything else I drive feels rubbish!
#22 DJ_Andy_M
DJ_Andy_M
  • 148 posts
  • Name: Andy
Posted 29 May 2012 - 12:05 PM
What you just stated there about steering is clearly very wrong. I have 1.6 zetec, and I have steering fluid, but I have steering options in the menus, and they do make a difference on which one I choose.
#23 r4963
r4963
    Member
  • New Member
  • PipPip
  • 10 posts
  • Name: Dave
Posted 30 May 2012 - 10:19 PM
Thanks this is exactly why I am so confused. I am therefore guessing yours is an 2008, 2009 model with the black vinyl stripes in the backs of the seats?
I had an 2008 model 1.6 Focus Zetec (had the stripes on the seats and standards wheels not sports pack and said "handling suspension" on Etis). Does that mean it had lowered stiffened suspension? I had to have replaced by the dealer as it had major fault.
This was replaced with a 2010 1.6 Zetec (no stripes on seats and no handling suspension according to Etis. Therefore not lowered and stiffened and essentially downgraded suspension?). From what I can see the only mark 2.5 model Zetec's that have handling suspension from 2010 onwards are the sports pack edition Zetecs with the larger alloys blackened windows and striped backed seats.)
This made me think that Ford basically downgraded the suspension on the standard Zetec from 2010 onwards to "standard". Which would make a Zetec not much of an updgrade on the model below. Anyone else agree?
Artscot79 explained in my other post that Zetecs have stiffer springs as standard compared to other Focus ie "standard" suspension. So I am kinda lost what the handling suspension was on the 2008, 2009 mark 2.5 spec Zetecs?
Anyone know the difference?
As for the steering setting I dont have that either. So I am thinking I kinda lost out with this 2010 model Zetec I have. Anyone have any ideas?
thanks.
#24 jg321
jg321
  • 207 posts
  • Name: Jon
Posted 31 May 2012 - 10:01 PM
thanks.
Yep, mine is registered December 2008, so 2008/2009 like you say, with the black stripes on the seats. Didn't really like them at first but I don't really notice them now! From what I've read, I'm under the impression that "handling suspension" does indeed mean it's stiffer. I'm guessing that if Etis says "standard suspension" then it does mean that the newer Zetec models don't have it as "standard". That does suck quite a lot, although I can see why Ford thought they were missing a trick!
Regarding the steering settings, I'm not sure, as from what I can gather all the diesels seem to have the option to change it. Only driven two, and they've both been diesel and had the settings.
Hope you get to the bottom of this, although it sounds as though you already have :(
Jon
Edit: forgot to ask, does the new car feel "less stiff" than the old one?
#25 r4963
r4963
    Member
  • New Member
  • PipPip
  • 10 posts
  • Name: Dave
Posted 09 June 2012 - 02:12 PM
Jon
Yep I think I have basically it seems like you say handling suspension is no longer included unless you get the sports upgrade.
In terms of stiffness I think it is a bit softer. Although between the 2008 focus and 2010 Focus I drove several Fiesta's so cant be certain. But I do have a memory of thinking that it was softer and smoother first time I drove this 2010 version. Still handles and stays quite flat in the corner, but I do get a bit of roll at speeds and it leans slightly.
How does yours handle in corners does it stay completly flat even at speed?
Looks like ive basically gotten to the bottom of it as you say
R
Not what you're looking for?
