Polish V Wax - What's The Difference?
Clean Polish Wax Wash swirl ford focus fiesta st zetec s
9 replies to this topic
#1 Marcr1
Marcr1
  • 801 posts
  • Name: Marc
  • Ford Model: Fiesta S1600
  • Year: 2012
Posted 18 May 2012 - 08:02 PM
Excuse me for probably sounding really daft here but what's the difference between polish and wax?
#2 iNath
iNath
    Ford Traitor
  • Super Mod
  • 2,722 posts
  • Name: Nathan
Posted 18 May 2012 - 08:15 PM
My understanding is that polish is something that takes a layer of lacquer/paint off to remove scratches - wax is an extra layer you put on to protect the paint.
Sure one of our cleaning gurus will be along shortly to clarify ;)
#3 Marcr1
Marcr1
  • 801 posts
  • Name: Marc
  • Year: 2012
Posted 18 May 2012 - 08:40 PM
Cheers! All I really want is that fresh out of the showroom look. Glistening in the sun 8) any ideas which is best?
#4 bikeit
bikeit
    Member
  • PipPip
  • 29 posts
  • Name: Sean
  • Ford Model: Fiesta Zetec
  • Year: 2007
Posted 18 May 2012 - 08:53 PM
Polish will remove light swirl marks and some contaminants from the paint work, it also gives you the shine, wax is just a protector, my favorites are Autoglym Super Resin Polish and Autoglym HD wax, i normally put two coats of wax on and leave a week between coats.
Before you apply any wax you will need to prep the paintwork first, check for bits of dirt etc stuck on the paint if this is the case you will need to clay before you apply any polish or wax.
My car
http://www.mazda3for...p?topic=10583.0
#5 Mark M.K
Mark M.K
    Club Manager
  • Management
  • 1,381 posts
  • Ford Model: 1.6 Fiesta Titanium
Posted 18 May 2012 - 09:23 PM
A polish will prepare the paint work for waxing. Some will remove light swirl marks, some don't. A polish will not offer any protection to paintwork. It is simply the second stage in getting the "perfect" detail. First stage would be to clay the car once every 6-12 months.
A wax will apply much easier on polished bodywork. If you wax a car without polishing, it will not bond to paintwork so easily, giving you less protection.
So to make things clear - a polish is the paint correction stage in prepation for waxing.
A wax is the protection stage. Wax will do nothing but protect paintwork from UV rays and beed water well.
#6 andrew43
andrew43
  • 223 posts
  • Ford Model: fiesta zetec-s mountune
Posted 19 May 2012 - 06:29 AM
go on www.detailingworld.co.uk all the info you will need,i would recomend Auto Finesse products which are very good
#7 Jenni Lynn
Jenni Lynn
    Newbie
  • Members via FB
  • Pip
  • 7 posts
Posted 19 May 2012 - 02:10 PM
Sorry to be thick but what's claying?
#8 bikeit
bikeit
    Member
  • PipPip
  • 29 posts
  • Name: Sean
  • Year: 2007
Posted 19 May 2012 - 06:12 PM
Claying is removing any contaminates from your paintwork before you start to polish and wax, i normally use Bilt Hammer clay as i find it a lot easier to use and you dont need any expensive lubricant for it, as a lubricant i normally use water and a very small amount of car shampoo in a spray bottle.
#9 andyedge
andyedge
  • 330 posts
  • Name: Andy
  • Ford Model: Frozen White 59 Fiesta Zetec S TDCi
  • Year: 2009
Posted 19 May 2012 - 10:49 PM
+1 to all of the above.
You can also add tar & iron oxide (rust) removal before the clay & polishing/waxing stages.
Use something like Tardis for tar removal & IronX for iron oxide removal before claying.
As stated above see detailing world forum for loooooads of info :)
#10 ReeceZetec1.25
ReeceZetec1.25
    Member
  • PipPip
  • 11 posts
  • Ford Model: Fiesta Zetec 1.25
Posted 20 May 2012 - 12:41 PM
As above using www.detailingworld.co.uk for great tips.
When I am doing a full detail will do/use the following:
Wheels and tyres with Bilberry Wheel Cleaner
Rinse wheels and whole of car
PH Neutral snow foam. Leave to dwell for 5/10 minuets
Rinse off and wash car with 2 bucket method
Rinse off car and leave wet ready for claying
Clay car with Megs Detailer and Clay bar
Re-wash car and dry
Spray car panels with Iron x and leave for 10 minuets
Wipe off with MF cloth - You can re rinse or re wash at this stage also.
Super Resin Polish
HD Wax
Regards
Reece
Also tagged with one or more of these keywords: Clean, Polish, Wax, Wash, swirl, ford, focus, fiesta, st, zetec s
