Help Needed
1 reply to this topic
#1 Makf2000
Makf2000
    Member
  • Budding Enthusiast
  • PipPip
  • 13 posts
  • Name: Mehmood
  • Ford Model: Focus 1.6 TDCI
Posted 26 May 2012 - 09:49 AM
Focus 1.6 TDCI 08 EML WARNING and loss of power when goin uphill DTC on dash fault is D900 .
Have something to contribute?
#2 btmaldon
btmaldon
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 2,581 posts
  • Name: Bruce
  • Ford Model: BMW 320i Coupe M Sport, KA Luxury
Posted 26 May 2012 - 04:00 PM
This is all I can find from an American Ford site.
The instrument cluster fault code D900 means...." non specific can [color=green !important][color=green !important]communications[/color][/color] interruption "
This does NOT mean you have a fault on the car. It's merely reporting that the networking around the car had an unidentified interuption in power supply.....so.....had a flat battery or jump start recently ?, maybe battery been disconnected for some reason ?
If the answer is no to the above, then have your battery tested. If battery is ok, have a battery reset done and code should disappear. ( remove negative lead from battery and hold to +ve lead for 2 minutres).
Now I wouldn't hold the negative lead to the positive under any circumstances, but disconnect the battery for about 30 minutes instead. Reconnect, start the car and let it tick over for 5 minutes and then take it for a drive.
If the car does have an issue, its best check for a code via the OBDII Port with a scanner. It should provide a code with more meaning.
Good luck
Not what you're looking for?
