Help, Battery Not Charging
david295
 Share
I have just put a brand new down pipe with flexi on, another new idle control valve, a new maf sensor, and now when i start car, the battery light is staying on, put tester on battery, and its not charging, i have not touched any wires.
Done dash test, and it comes up with DTC 9202 and E002
Link to comment
Faulty alternator ?
Link to comment
Its been fine for 2 weeks, and to day just changing exhaust flexi, and 2 other bits, it just dont work no more, surly it must be something else
Link to comment
9202 is a faulty fuel sender or wiring if the battery isnt charging check the alternator wiring its not that far from the flexi also theres a fuse in the bay for the alternator to save money a garage would be best that way you only fix what needs fixed
Link to comment
i have checked fuse in fuse box in engine bay, they are fine.
Link to comment
before buying take the car to a garage and have it looked at a battery test is free you want a silver calcium battery like Bosch silver
Link to comment
the likes of KwikFit will do a battery health check FOC for you :)
Link to comment
have you made sure the battery is silver calcium a non silver calcium is known to fry the regulator
Link to comment
this is the one rac said was for focus with smart chatge, more problems tonight, when i am coming to traffic light, and slow down, and stop, car almost stalls, tick over goes very very low, also when i switch on heater full, head lights go really dim, the revs drop as well, is this a duff battery i got from rac
Link to comment
a battery test is the way to find out mate garages do them free and check the alternator as well its either the battery the alternator itself or the wiring to the alternator or the fuse for the smart charge in the engine bay fuse box
Link to comment
What type of battery is fitted? a calcium type?
This is the battery fitted http://www.racshop.co.uk/car-battery/product/bosch-s5-car-battery-075.html this is the one the rac recommended and came out and fitted, it's brand new fitted yesterday, and had alternator reconditioned, as regulator had died, but last night at work, when I put the heater on full, the head lights go very dim, i have just had battery tested, and as i expected, its excellent, alternator is kicking out right volts aswell, but yet when i put heater on full, the headlights dim, and car allmost stalls.
If am approaching traffic lights, and stopping, the engine almost stalls, seems to be worse when i press break
Link to comment
if you disconnect the 3 wire plug from the alternator with it running, does it stop it trying to stall when you switch things on? mine used to do this but i never found the cause
Link to comment
if this solves it, would it do any damage leaving it unplugged or any damage unplugging it, also revs are still high when first started, takes about an hour before they settle to normal, it still does this when ever you start it, hot or cold engine makes no difference, rac man has just left, he plugged his computer into car, and it shows no faults at all, it all shows as everything working as it should
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
