2003 Focus 1.6 Attempted Stalling!!
5 replies to this topic
#1 roxy
  • New Member
  • Pip
  • 2 posts
  • Name: roxy
  • Ford Model: focus ebony
  • Year: 2003
Posted 06 June 2012 - 07:11 PM
Iv got a 1.6 focus.
It wasnt running right i.e 'juddering' 'missing when accelerating and slowing down"
So spark plugs,leads,coil pack,battery reset done
That corrected that problem but now its is trying to stall when idolising.
When at traffic lights or just statonary.
It goes to stall but the revs blip and it saves itself.
I had diagnostics done which said irregular air flow or intake.something like that.so inlet gaskets got cleaned and sealed. but its still doing it really bad.
Any clues anyone??
Have something to contribute?
#2 Andy 1965
Andy 1965
  • New Member
  • 82 posts
  • Name: Andy
  • Ford Model: Focus 1.6 Zetec
  • Year: 2002
Posted 06 June 2012 - 08:02 PM
I would check positive crankcase ventilation valve and associated pipework for air leaks. Also Idle air control valve and throttle position sensor. Do you have an engine management light coming on in your dash?
#3 johnH
  • 1,145 posts
  • Name: John
  • Ford Model: Focus mk2 Zetec 1.8 TDCI (Climate)
  • Year: 2006
Posted 06 June 2012 - 11:13 PM
could be your Mass Airflow Sensor...well thats what it translates to me, so i could be wrong.
this sensor is located just after your air filter, pretty easy to see and remove...alot of money though to replace....those cheap ones on ebay wont work.
#4 btmaldon
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 2,592 posts
  • Name: Bruce
  • Ford Model: KA Edge, BMW 320i Coupe M Sport
  • Year: 2015
Posted 07 June 2012 - 11:43 AM
The most common reason would be the Idle Control Valve (Air Bypass Valve). It may be worth taking it off and giving it a clean first with some carb cleaner to see if that makes a difference as they do soot up.
#5 DJ_Andy_M
  • Budding Enthusiast
  • 148 posts
  • Name: Andy
  • Ford Model: Ford Focus MK2.5 Facelift Zetec
Posted 07 June 2012 - 03:23 PM
I also recommend cleaning your idle control valve. Sounds very much like the problems I had with my Escort. It was notorious on the Escorts for being a problem, along with the mass airflow sensor.
#6 FocusGhia16V
  • New Member
  • Pip
  • 9 posts
  • Name: Stewart
  • Ford Model: Focus Ghia 1.6
  • Year: 2001
Posted 09 June 2012 - 08:22 AM
Yep.....IACV gets my vote.
Not what you're looking for?
