S Max Cruise Control Problem
3 replies to this topic
#1 TOMSK65
TOMSK65
    Newbie
  • Pip
  • 1 posts
  • Name: Tom
  • Ford Model: S Max
Posted 08 June 2012 - 10:51 PM
I have a 2.0 TDi Titanium 6 Speed Manual which has lately developed a fault. When I try to use the cruise control it sometimes works and other times it doesn't for example when I press the activate button as soon as I press the + button it turns off! and other times it works without a problem. I don't do too much motorway driving so I haven't noticed it before now. The car was recently serviced and MOT'd where i was advised that my front brake pads were low, could this be the cause or is it more likely a faulty clock spring in the steering wheel?
Anyone have this same fault that could give me some advice? Obviously I will get the front pads changed in the next few weeks.
#2 gregers
gregers
  • 194 posts
  • Name: greg
  • Ford Model: smax titainium
Posted 09 June 2012 - 08:31 PM
are you trying to activate it above 30mph ?
im sure ive tead somewhere it has to be above something like that?
i know the old galaxys used to be that.
#3 137699
137699
  • 215 posts
  • Ford Model: 2006 S-max Titanium X Sport 2.5T
Posted 10 June 2012 - 07:45 PM
Cruise control problems are often related to the ABS sensors / reluctor rings.
#4 philip2005mg
philip2005mg
    Newbie
  • Pip
  • 1 posts
  • Ford Model: S-max
Posted 31 August 2012 - 10:27 PM
I had the exact problem with my S-Max cruise control cutting out when you pressed + or - buttons. Frustrating.
Dealer diagnosed a faulty steering wheel switch assembly - fixed for £125!
Hope this helps.
