Leaky Sunroof
2 replies to this topic
#1 Goose1505
Goose1505
    Newbie
  • New Member
  • Pip
  • 2 posts
  • Name: Sean
  • Ford Model: Escort MK3 1600 Ghia
  • Year: 1980
Posted 09 June 2012 - 09:53 AM
I have a leaking sunroof on my MK3 Escort. I turned to Ford for help, but there wasn't much they could do for a 32yr old car!
Has anyone out there had the same problem, have any tips on repair or know of a specialist I can take it to?
The last thing I want to have to do is seal it shut
Just thought I should mention that I have checked the drain channels and the are clear and running freely
Have something to contribute?
#2 gregers
gregers
  • True Ford Enthusiast
  • 950 posts
  • Name: greg
  • Ford Model: smax titainium tdci
Posted 09 June 2012 - 08:36 PM
1st off clear all crud out from around the seals,then watch how it closes from both inside and out.
then take a looksie at the workings,iirc on fords it will be a couple of torx screws.undo them 1 at a time push the roof up into the seal of the roof and retighten do the same on all you see.hopefully this may cure your problems?
#3 Goose1505
Goose1505
    Newbie
  • New Member
  • Pip
  • 2 posts
  • Name: Sean
  • Year: 1980
Posted 10 June 2012 - 06:17 PM
Thanks for your advice on this. It would appear some one has already had a go at doing this and stripped the threads in the process!
Thanks anyway.
Not what you're looking for?
