Abs Quandry
3 replies to this topic
#1 Chris James
Chris James
  • Members via FB
  • Pip
  • 1 posts
Posted 11 June 2012 - 05:57 PM
Hi Guys (and girls) I've got a 2002 '52' 1.8 LX with a baffling ABS issue. ABS light is on and they are not funcitoning (wheels lock up). When I put in the code reader to fault find the warning light goes out and no fault codes are found by the reader. Drive down the road 50 yds the light comes back on, try again the light goes out and no coeds found, any ideas? I'm stupmed by this.
Have something to contribute?
#2 mintalkin
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 3,573 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 11 June 2012 - 06:08 PM
when you turn the ignition on does the airbag light fash as this can be read as a flash code,,also check the plugs under the drivers seat as these can become loose and create a dodgy connection especially if the seat is ofter slid back and forth for different drivers.
#3 wimiu012uk
  • New Member
  • 31 posts
  • Ford Model: mk3 mondeo 2lt tdci 130bhp ghia
Posted 12 June 2012 - 04:23 PM
I had a similar problem on my fiesta, abs light was on all the time and when braked the rears especially locked up so abs was definetly NOT working.
Took car to Ford as it was only 2 yrs old and they found that the ABS pump module was faulty, cost me £800 to have job done. Could have bought a recon unit from ebay etc but would still have had to take to Ford to have the computers reset or whatever they tell us they do, with no guarantee that the recon unit was 100%. Cost of that route was approx £500, so I bit the bullit and payed full amount with peace of mind that there was a 12mth guarantee on ABS pump module and it would fix the problem.
#4 stef123
  • Management
  • 6,089 posts
  • Name: Stefan
  • Ford Model: Mondeo ST TDCI
  • Year: 2006
Posted 12 June 2012 - 04:29 PM
are you using an ABS fault code reader? a standard engine fault code reader won't work.
Not what you're looking for?
