Glove Box
4 replies to this topic
#1 Gaz03
Gaz03
    Newbie
  • New Member
  • Pip
  • 3 posts
  • Name: Gary
  • Ford Model: LX
  • Year: 2003
Posted 12 June 2012 - 07:11 PM
Can anyone tell me how to remove the glove box damper so as to replace with new one? Can see it but no way seems to get it out? Thanks. :(
Have something to contribute?
#2 Mr Ford
Mr Ford
    Member
  • New Member
  • PipPip
  • 11 posts
  • Name: Bob
  • Ford Model: Focus 1.6 Edge
  • Year: 2007
Posted 12 June 2012 - 11:19 PM
what car is it, most fords if you lower the glovebox and unclip it so it hangs down then twist the damper about 45 degrees then it will come out
#3 Stoney871
Stoney871
    Resident Peacekeeper
  • Super Mod
  • 17,757 posts
  • Name: Clive
  • Year: 2015
Posted 13 June 2012 - 12:39 AM
If you have a Focus you need to remove the glovebox to get proper access to the damper.
Push the sides in to hinge the box down and that will give you access.
I believe the damper is held on by a bar twisted into a slotted hole.
Rotate and line up the bar and slot and withdraw.
If it's a Mondeo, there is a catch on one end to depress so as to release the mounting spindle and the other end is a arrowhead type clip.
#4 Gaz03
Gaz03
    Newbie
  • New Member
  • Pip
  • 3 posts
  • Name: Gary
  • Ford Model: LX
  • Year: 2003
Posted 13 June 2012 - 05:09 PM
Thanks for the replies. I got as for as the damper but despite turning it, the arrowed end of it doesn't seem to want to release? Was the reply from Bob the answer? must give it a try. Once again Thanks. Gaz. Mondeo mk3. Thanks stoney, is it the arrowhead end that needs twisting to line up?
#5 Stoney871
Stoney871
  • Super Mod
  • 17,757 posts
  • Name: Clive
  • Year: 2015
Posted 13 June 2012 - 05:16 PM
Not sure how you release the arrow head.
May be twist or you may need to fiddle around with screwdrivers/pliers.
Not what you're looking for?
