Stereo Problem
8 replies to this topic
#1 Azz123
Azz123
    Newbie
  • New Member
  • Pip
  • 8 posts
  • Name: Arren
  • Ford Model: Studio
  • Year: 2007
Posted 16 June 2012 - 08:29 PM
Hi guys,
I've got a Ford Focus studio 2007 model and today i've had a problem...
I tried fitting a new stereo using adapters from the original ford stereo plug... I fitted my new stereo and it shorted out...
Now neither the new stereo or the original ford stereo will work at all...
I need a fuse map to check the fuses and to see what i can do..
Also a note on this one is that when i originally had my ford stereo in the would work fine but other stereos had stopped working... i found this a bit odd?
Also i have a problem where my dash takes about 10-15 seconds to load up... It has a red arrow pointing upwards and nothing will turn on for about 10-15 seconds until the dash has started...
Have something to contribute?
#2 oilburner79
oilburner79
  • Members via Twitter
  • 109 posts
  • Name: darren
  • Ford Model: Focus Zetec Collection
  • Year: 2000
Posted 16 June 2012 - 09:05 PM
It sounds like the fuse has blown does your 12v socket not work either?
#3 Azz123
Azz123
    Newbie
  • New Member
  • Pip
  • 8 posts
  • Name: Arren
  • Year: 2007
Posted 17 June 2012 - 09:06 AM
Yeah thats what i think but i need the fuse map to figure out which one it is! Also my lighter socket aint working either so yeahi know its the fuse haha :)
#4 james_60
james_60
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 1,022 posts
  • Name: Jamie
  • Ford Model: 2013 Focus Titanium X 1.6TDCI 115BHP
  • Year: 2013
Posted 17 June 2012 - 09:36 AM
Hi arren
Iam just wondering what actually made it short out.
If it blows again i would suspect the replacement head unit is faulty
Jamie
#5 Azz123
Azz123
    Newbie
  • New Member
  • Pip
  • 8 posts
  • Name: Arren
  • Year: 2007
Posted 17 June 2012 - 09:55 AM
Hi Jamie
it was my fault it shorted out i rewired the head unit from the new stereo because the block connecters were faulty and i completely forgot to put insulating tape around them... so when switching on bang and it shorted out
Cheers
Arren
#6 johnH
johnH
  • 1,138 posts
  • Name: John
  • Ford Model: Focus mk2 Zetec 1.8 TDCI (Climate)
  • Year: 2006
Posted 17 June 2012 - 10:56 AM
if you look in your owners manual, it lists all the fuses and their purpose in both the glovebox and engine fusebox.
#7 Azz123
Azz123
    Newbie
  • New Member
  • Pip
  • 8 posts
  • Name: Arren
  • Year: 2007
Posted 17 June 2012 - 11:10 AM
I've looked in the manual it says there's a cover over the fuse box under dash but it ain't there so I'm a bit stuffed "/
#8 greggp
greggp
  • Budding Enthusiast
  • 274 posts
  • Ford Model: Focus 2008 1.8 petrol Titanium
Posted 18 June 2012 - 11:17 AM
If the 2007 model is the same as mine (2008 facelift) then check to see if your Fuse board is underneath the glove-box. If so, the fuse board is held up by 2 plastic screws, undo these and the fuse board drops down so you can access all fuses. The fuse for the cigarette 12v will be a yellow (20-amp). Map of fuse locations is detailed in the manual.
Hope this helps.
#9 greggp
greggp
  • 274 posts
Posted 18 June 2012 - 11:22 AM
have a look at this
Not what you're looking for?
