Rear Lower Suspension Arms Problems
17 replies to this topic
#1 lee-st170
lee-st170
    Newbie
  • New Member
  • Pip
  • 3 posts
  • Name: lee
  • Ford Model: focus st170
  • Year: 2002
Posted 17 June 2012 - 07:27 PM
hey guys reading up on lowering my st170 should be easy i thought but looks like there is a problem with the rear lower arm bolts being seized up :-( so before i give it ago can someone please give me some advice hints or tips please also the bolts can i only get them from a ford dealership? also is there a diagram of the rear suspension for me to have a look at any help would be very greatful
many thanks
Have something to contribute?
#2 stef123
stef123
  • Management
  • 5,871 posts
  • Name: Stefan
  • Ford Model: Mondeo ST TDCI
  • Year: 2006
Posted 17 June 2012 - 07:37 PM
yup, the bolts will be seized into the bushes. ford should be able to supply the bolts but you can bet you will have a hard time getting them out.
even with a good impact gun is difficult as the bush moves.
#3 focus zetec s black
focus zetec s black
  • New Member
  • 53 posts
  • Name: dean
  • Ford Model: focus zetec s 08
Posted 17 June 2012 - 07:40 PM
many thanks
never lowerd a early st but most bolts on any suspention leg etc are exposed to the elements...just good tools bit of wd40/wire brush and a good gym session should get them out failing that a tad of heat/the freezing stuff is crap in my opinion....last resort would be to cut them of and yes replace but just have a go at cracking them of first....as above maybe you can make some kind of puller press to push them out.
#4 lee-st170
lee-st170
    Newbie
  • New Member
  • Pip
  • 3 posts
  • Name: lee
  • Year: 2002
Posted 17 June 2012 - 07:44 PM
cutting the bolts sound to be the best idea but they have a welded nut on them would that matter cutting it off ?
#5 focus zetec s black
focus zetec s black
  • New Member
  • 53 posts
  • Name: dean
Posted 17 June 2012 - 07:49 PM
not to sure without a pic but if there coming out and there being replaced i would say it was fine
#6 stef123
stef123
  • Management
  • 5,871 posts
  • Name: Stefan
  • Year: 2006
Posted 17 June 2012 - 07:55 PM
you could always try a set of cut down spring compressors to get the old springs out. be careful if you go down this route though
#7 artscot79
artscot79
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 8,003 posts
  • Name: arthur
  • Year: 2006
Posted 17 June 2012 - 08:51 PM
the bolts wont budge ford tried heat wd40 impact guns in the end they had to drop the subframe down the bolts are tight against the arms if u cut them you ruin the arms no matter how you cut them
#8 poshpawsfiesta
poshpawsfiesta
    AKA PoshPawsRenaultClio
  • New Member
  • 465 posts
  • Ford Model: fiesta
  • Year: 2016
Posted 17 June 2012 - 10:40 PM
Im having mine replaced under warrenty as they are siezed on, i found out when i thought the rear wheel wasnt sittting propally so ford tried to do 4 wheel lazer tracking and couldnt do it because of these bolts were sized.
#9 artscot79
artscot79
  • PipPipPipPipPip
  • 8,003 posts
  • Name: arthur
  • Year: 2006
Posted 17 June 2012 - 11:10 PM
ford do not grease these bolts at the factory all ford dealers know the easiest way to replace springs etc is to drop the rear subframe.other garages will tell you the arms need cut destroying the arms and the rear beam
#10 bt_cav
bt_cav
  • New Member
  • 331 posts
  • Name: Brian
  • Ford Model: focus
  • Year: 2004
Posted 17 July 2012 - 06:47 PM
Hi guys,
Just read thru this thread as I'm hoping to replace both my rear springs and shocks as 1 of my springs is broken. Not interested in lowering, just going to replace with good quality springs & shocks.
I was just wanting a heads up to see how different my 04 1.6 LX is with regards to changing these.
Cheers Brian
Also...
I was looking thru the Boge catalog at springs, and Im curious to know what diffrence heavy duty springs would make?? Maybe they would last longer as I do around 25K every year (especally over all the speed bumps & potholes)
http://webcat.zf.com/index.asp?SPR=4
Futhermore....
If I were to use heavy duty springs Id also be looking to use heavy duty shocks, but which is heavy duty? super touring or advantage??
#11 bt_cav
bt_cav
  • New Member
  • 331 posts
  • Name: Brian
  • Ford Model: focus
  • Year: 2004
Posted 18 July 2012 - 11:13 AM
Hey Guys dont mean to hijack this thread but didnt want to start a new topic when there is already a good one with good input already :)
looking forward to your oppions
#12 raskL
raskL
  • New Member
  • 82 posts
  • Name: phil
  • Ford Model: Focus
  • Year: 2007
Posted 18 July 2012 - 11:25 AM
i always weld another bolt to the top of the stuck bolt and then give it some elbow grease! :P
#13 bt_cav
bt_cav
  • New Member
  • 331 posts
  • Name: Brian
  • Ford Model: focus
  • Year: 2004
Posted 20 July 2012 - 10:18 AM
sounds like plan, sadly I dont have any welding kit............just a few big boxes of tools and a coulple of jacks & stands.
Priced springs & shocks - £162
Called kwick-fit for a price and was quoated around £330 :o so needless to say I'll not be going there.
Going to have a go at slacking off the lower shock bolt..............never know I might get lucky :rolleyes:
#14 stef123
stef123
  • Management
  • 5,871 posts
  • Name: Stefan
  • Year: 2006
Posted 20 July 2012 - 12:32 PM
the shock bolt will undo fine, its the bolts that pass through bushes in the arms. they corrode inside the sleeves and you can never get them out again!
#15 bt_cav
bt_cav
  • New Member
  • 331 posts
  • Name: Brian
  • Ford Model: focus
  • Year: 2004
Posted 20 July 2012 - 10:32 PM
Nice one Cheers Stef :)
once again your words of wisdom make it all clear :D
I'll wire brush what I can and soak with release oil before I attempt it ;)
do you have any thoughts reguarding 'heavy duty' springs & Shocks?
Not what you're looking for?
