Have an 07 Ford Focus and just bought some Ford roof bars to use with cycle carriers .Tried them yesterday to make sure they were ok and then removed them as i wont be using them for a while. My only concerned is that now i have removed the sealant from the roof panels where the screw goes in whats to stop water getting into the holes and causing rust etc when the roof bars aren't in use ?
Ford Focus Roof Bars Sealant Question
Started by chuzzwuzzer, Jun 18 2012 09:25 AM
5 replies to this topic
#1
Posted 18 June 2012 - 09:25 AM
#2
Posted 18 June 2012 - 06:50 PM
I just put in some bolts with rubber washers to seal the holes.
Cheers
Paul-S
Cheers
Paul-S
#3
Posted 19 June 2012 - 01:53 PM
I've just left it as is, doesn't seem to have caused any harm.... I kinda trusted Ford had thought this one through
#4
Posted 20 June 2012 - 02:10 PM
Well now theres a neat little square cut out of the sealant and with the actual hole for the bolt i'd imagine its just going to fill up with water and stay like that .If it didn't need it why would ford gob it up with sealant in the first place .Maybe i'm worrying over nothing.I'll try and find some bolts that will fit and try the rubber washer method
#5
Posted 20 June 2012 - 07:19 PM
Hi guys i did exactly the same couple of small bolt with a rubber "o" ring to seal just in case not had any problems over the last 8 months.
#6
Posted 20 June 2012 - 07:32 PM
Cheers
Paul-S
I would give each bolt hole a shot of WD40 before you put the bolts in just to stop any rust forming, make sure they are dry first.
