Start Button / Audio Question
mitch84
Hi
I have always wondered if its possible to keep the radio on when I turn my cars engine off.
I have the keyless start button and every time I press it to turn off the engine everything goes off as well.
Is there a way to turn just the engine off when pressing it?
thanks
Usually you can press the radio power button to enable the radio for one hour.
hi
Yeah I do that , I know its not a pain to do , it would just be good if it wouldn't turn off when I press the start button , cant have everything :)
cheers
I suppose you could disconnect the ignition link at the back of the radio loom but is it really worth all the effort for something that only requires a push of a button?
Hi
thanks
I just press the button again - pre ignition so radio is on then press ok on steering wheel as car screen will tell you door open and keyless is engaged !
Wouldn't it be easier just to turn the radio back on for the 1 hour countdown as Stoney suggested? <_<
soz if im wrong but when you start the engine you have to put clutch down right? otherwise you just turn on the power is there not like a reverse to that, like clutch down and off button.... or off button without clutch??? just a suggestion...
Mines the same but to be honest if it didn't turn off everyone would be forever leaving them on and not noticing.
