Aux Belt
15 replies to this topic
#1 johnS
johnS
  • Budding Enthusiast
  • 413 posts
  • Name: John
  • Ford Model: Focus 1.6L MK1.5
  • Year: 2004
Posted 25 June 2012 - 12:41 AM
Just had the aux belt done with an alternator.
Checked the belt while it's been running and off and both times seems fine
But When a load such as a/c is put on, the alternator voltage drops and makes the lights flicker whenever the a/c clutch engages, similarly, when the power steering is put under a heavy load, the alternator voltage will drop also.
Power steering feels heavier than before, but its still usable.
I want to know what the problem is first before I take it back, does anyone know what it could be and if I leave it like this (because to be honest, while the alternator voltage drops sometimes when a load on the belt is placed, it all seems fine really, just heavier steering and flickering with a/c) will any damage occur to the parts being driven by the belt.
There is definatly no squeeling noises as if a belt was slipping, and no other chirping noises, it sounds really healthy tbh.
Any help?
Have something to contribute?
#2 Stoney871
Stoney871
    Resident Peacekeeper
  • Super Mod
  • 18,105 posts
  • Name: Clive
  • Year: 2015
Posted 25 June 2012 - 12:45 AM
Only logical answer is the belt is not tensioned properly.
#3 johnS
johnS
  • 413 posts
  • Name: John
  • Year: 2004
Posted 25 June 2012 - 12:46 AM
Does it not have an auto tensioner? It has a 1.6L Zetec SE with air condtioning
#4 Stoney871
Stoney871
  • Super Mod
  • 18,105 posts
  • Name: Clive
  • Year: 2015
Posted 25 June 2012 - 12:48 AM
Are you sure the tensioner is working correctly?
#5 johnS
johnS
  • 413 posts
  • Name: John
  • Year: 2004
Posted 25 June 2012 - 12:51 AM
Pretty sure yes, because theres no noise whatsoever comming from the engine, at least at idle speed and it doesnt slip
#6 Stoney871
Stoney871
  • Super Mod
  • 18,105 posts
  • Name: Clive
  • Year: 2015
Posted 25 June 2012 - 01:16 AM
Was the alternator brand new? the voltage regulator on the top of it may be malfunctioning.
I'd start by checking the voltage across the battery, it should be 14v+ on idle.
If it's lower than that then the alternator, battery or regulator may be faulty.
Have a read of this article for possible test procedures to locate a voltage drop.
http://www.engine-li...ltage-drop.html
#7 johnS
johnS
  • 413 posts
  • Name: John
  • Year: 2004
Posted 25 June 2012 - 01:50 AM
thanks for the replies
I still beleive it to be the belt because the power steering is heavier than before (especially with a/c)
#8 johnS
johnS
  • 413 posts
  • Name: John
  • Year: 2004
Posted 25 June 2012 - 11:47 AM
Anyone?
#9 artscot79
artscot79
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 7,929 posts
  • Name: arthur
  • Year: 2006
Posted 25 June 2012 - 01:33 PM
john mate the only one who can diagnose this is ford they can use oscilators to check the alternator smart charge wave form theres so many possibilities here from the wrong alternator to a faulty alternator to the voltage regulator to a trapped or broken wire to get a definitive answer ide take it to ford and have it diagnosed
#10 johnS
johnS
  • 413 posts
  • Name: John
  • Year: 2004
Posted 25 June 2012 - 02:56 PM
Its not the alternator, though. Im pretty sure its the belt. Is there any tests I can do to the belt to check its tension?
#11 NorthSussex
NorthSussex
  • 976 posts
  • Name: Stormin
  • Year: 2009
Posted 25 June 2012 - 04:03 PM
John, take artscot's advice or you will continue to go round and round in circles, there is no magic wand that will sort your Focus out; you have been here before with other problems.
#12 johnS
johnS
  • 413 posts
  • Name: John
  • Year: 2004
Posted 25 June 2012 - 04:13 PM
Might just leave it then. Really cant afford to go to Fords at the moment, Im a student
#13 NorthSussex
NorthSussex
  • 976 posts
  • Name: Stormin
  • Year: 2009
Posted 25 June 2012 - 04:17 PM
John, don't be a wimp, if the garage did the work and you feel it's still faulty, TAKE IT BACK AND GET IT FIXED UNDER WARRANTY.
#14 johnS
johnS
  • 413 posts
  • Name: John
  • Year: 2004
Posted 25 June 2012 - 04:42 PM
i think it's time I found another garage also
#15 NorthSussex
NorthSussex
  • 976 posts
  • Name: Stormin
  • Year: 2009
Posted 25 June 2012 - 04:47 PM
Yep! <_< But get them to fix your car first.
Not what you're looking for?
