Mk 2.5 58 - Retrofit Bluetooth & Usb Questions
bluetooth usb retrofit sony titanium
37 replies to this topic
#31 jonnyp672
jonnyp672
    Newbie
  • Budding Enthusiast
  • Pip
  • 9 posts
  • Name: Jon
  • Ford Model: Focus ST-3 Mk2.5
Posted 12 March 2014 - 01:39 PM
Yeah I do. It is the sat nav unit with the climate built in. I'm sure it is called the NX unit.
Have something to contribute?
#32 Willy
Willy
    1.0 EcoBoost MR165 Mountuned
  • 2,388 posts
  • Name: Willy
  • Ford Model: Fiesta 1.0 Titanium X Midnight Sky
  • Year: 2015
Posted 12 March 2014 - 01:42 PM
Get over to the Focus ST owners club Jon and become a member. It a really good site.
Full membership is only £6 and has loads of info that you'll find interesting
http://www.focusstoc...rship-6-months/
Don't forget to look out for a guy over there called xfileswilly ;)
http://www.focusstoc...01-xfileswilly/
#33 Gaz RS
Gaz RS
  • 102 posts
  • Name: Garry
  • Ford Model: Focus RS
  • Year: 2009
Posted 12 March 2014 - 02:37 PM
This guide is for the Sony 6 disc dab but will give you a good idea of what's involved, I can remember reading that the NX unit has a mic built into it for voice commands this might explain the stalk with the voice button.
 http://www.fordowner...for-focus-mk25/
Also have a read through this, it's for the Kuga but has reference to the NX unit
 http://www.kugaowner...1669_page1.html
#34 Willy
Willy
  • 2,388 posts
  • Name: Willy
  • Year: 2015
Posted 12 March 2014 - 02:45 PM
Looks similar to my old guide Gaz :)
Perfect
#35 jonnyp672
jonnyp672
    Newbie
  • Pip
  • 9 posts
  • Name: Jon
Posted 12 March 2014 - 04:30 PM
My unit definitely has a mic as it does respond to voice commands. Would this mean I wouldn't need the Mic patch cable?
#36 Gaz RS
Gaz RS
  • 102 posts
  • Name: Garry
  • Year: 2009
Posted 12 March 2014 - 06:26 PM
Have a look for both the module and mic connectors if you have these I think you would be good to go.
Read through the Kuga thread but I think you will need the the patch cable if not both
#37 Bruno_131085
Bruno_131085
    Newbie
  • Pip
  • 2 posts
  • Name: Bruno
  • Ford Model: Focus
Posted 18 May 2014 - 09:41 AM
The loop connector is only present on the new Bluetooth/Voicecontrol wiring. The old wiring did not have a loop connector.
The loop connector is usually pretty hard to find. It should be taped on the interior wiring loom and can not be seen without removing the tape.
The retrofit wiring harness could be a good solution for your problem but in my opinion it is a bit expensive. It would be much cheaper to completely check your cars wiring and modify it if needed.
I retrofitted the complete MK2.5 Sound & Connect system (Bluetooth/Voicecontrol with USB, Ipod an Bluetooth Audio support) into my 2005 MK2. I made all the wiring myself using an interior wiring loom of a Focus MK2.5. At the time I did the retrofit there was almost no information/experience with retrofitting this system. At that time I took the interior wiring loom apart. By reverse engineering I made a schematic drawing of the MK2.5 Bluetooth/voicecontrol wiring.
Hi! I have a Feb'08 ford focus Titanium mk2.5. First I updated my rádio sony to sat nav blaupunkt travelpilot nx and recently i switch my Nokia bt module for the novero one w/ USB. As it's expected in this model there where no sound but for my surprise, the wiring in my car is just like this schemating drawing. Even the colors of the wires are the same. It's supose to working no? Any clue of what is missing here? It's because the travelpilot? Do I need update the SRM configuration?
Regards
#38 yunii
yunii
    yunii
  • True Ford Enthusiast
  • 802 posts
  • Name: yunii (nickname)
  • Ford Model: FOCUS TITANIUM-S
Posted 18 August 2014 - 06:34 PM
I have found a bluetooth module block in glovebox & this grey block with a loop i do have a mic as i can feel wire from it & 2 wire block behind maplight.(mine is 2010 titanium)
Connecters behind glovebox
So do i only need module & audio voice stalk?
Btw i had single cd dab sony but upgraded to 6cd dab sony. If it matters.
Yunii
Not what you're looking for?
Also tagged with one or more of these keywords: bluetooth, usb, retrofit, sony, titanium
