frund
Where Is The Oil Filter 08 1.6 Zetec Diesel
4 posts in this topic
Hi, Used to change my own oil and filter but garages became very reasonable so I let them do it. Now £80 for oil and filter change, parts £30 so worth the effort big saving. Problem is I can't see where the oil filter is hiding any one know where it may be. thanks
Since posting i have taken off the air cleaner and top trim piece and I think it is on the right side of the engine block but not a tall as the usual filter housings with one largeish nut. I looks as if the filter may go down into a alloy housing with just a short metal dome for access. One main air pipe will have to be removed very easy 2 cross heads. Will know for sure weekend when I have the bits. I could do with a manual hmmm.
Yes, you are on the right lines there. Its under the air intake..
Good show, I will do it sat morning saving a few quid. Thanks
