Sound Like A Clutch Problem?
#1
Posted 05 July 2012 - 12:21 AM
Okay, so I have a certain problem with my Ford Ka, 2003 model. Any time I don't have my foot pressed down on the clutch, I get this hissing noise that seems to come from the behind the dashboard, although you can easily hear it if stood outside of the vehicle, so perhaps it's under the bonnet itself.
If I have the clutch to the floor, the sound goes away; whether I'm driving it or just have it in one place. I fear that it's the clutch, as the noise goes away when it's engaged, so to speak.
I took my car to a local mechanic, explaining the problem, but he couldn't find anything wrong with the car... however, when I took it to him, the problem was only slight - if I used the car, then left it for a few hours, and restarted it, the noise wouldn't be there. I think he may not have given the clutch a thought, as he suggested that it could be the gears behind the dashboard that must turn to keep a check on how many miles I'm doing (does that even happen?). The problem has got worse since then, and happens whenever I turn the engine on.
My Ford KA is an old model, and does not give a reading behind the wheel of how many RPM (if that is the right word) there is.
I have an MOT check on the 6th of this month, and plan to bring it up with him then. However, if anyone could give me some sort of clue as to what the problem could be, I would appreciate it greatly.
#2
Posted 05 July 2012 - 01:44 AM
If you open the bonnet and start the engine, can you pin point roughly where it's coming from? If its a hiss it's got to be a leak somewhere
#3
Posted 05 July 2012 - 01:48 AM
Did he offer to change the indicator fluid and replace the air in your tyres at the same time?
Some mechanics do talk a load of old toss.
#4
Posted 05 July 2012 - 01:58 AM
Giggling pin and laughing shaft sprIng to mind with that lot
#5
Posted 05 July 2012 - 02:11 AM
He said he did a quick look over it (I was there about a different problem that he fixed), didn't look too in depth, just at "basic" areas and couldn't see anything wrong with the car. His guess was that it could be something behind the dashboard. The problem he fixed was about air in my tyres... one was shaking, so he put in some air and balanced it, works fine now.
I don't think he's too bad of a mechanic. The wheel problem he fixed for free. He said the gear thing was only a guess, and unless it actually affects the performance of the car, I should leave it until I get the MOT and he'll do a thorough check-over of it.
I'll try to pinpoint the location of the hissing noise tomorrow (It's late at night now). I know that it comes from the drivers side, however, if that helps at all?
#6
Posted 05 July 2012 - 03:18 PM
#7
Posted 05 July 2012 - 03:21 PM
#8
Posted 05 July 2012 - 07:17 PM
#9
Posted 05 July 2012 - 07:27 PM
#10
Posted 05 July 2012 - 08:23 PM
Does the water pump help to supply cold air to the fans? I'm having a problem with my fans too; always blowing hot air, even when they are switched off. Although I suppose that could be many different factors - things blocking the fans, leaks, etc.
Yeah, my car sucks, lol.
#11
Posted 05 July 2012 - 08:28 PM
#12
Posted 05 July 2012 - 08:32 PM
#13
Posted 05 July 2012 - 08:34 PM
It's just a couple of hose connections and an electrical connector. Top up the coolant and bleed the system.
#14
Posted 05 July 2012 - 08:49 PM
#15
Posted 11 September 2012 - 08:14 PM
Also tagged with one or more of these keywords: Clutch, Gears, Other Problems
United Kingdom - General Ford Discussions by Model →
Ford Focus Club →
Focus Clutch?Started by Chumley01273, 21 May 2013 |
Ford KA / StreetKA Club →
Streetka Electric And Noise IssueStarted by Tiggi, 09 May 2013 |
Ford Focus Club →
Knocking And Vibration After Clutch And Dmf ReplacementStarted by glennkelly, 25 Apr 2013 |
Ford Focus Club →
Dmf Or Solid FlywheelStarted by Stoodz, 18 Mar 2013 |
Ford Mondeo Club →
The Dmf/smf Conversion DebateStarted by stooge75, 01 Feb 2013 |
