FIESTA_MAD Posted July 8, 2012 Share Posted July 8, 2012 hi used the guide on here to remove my grille and it can off with a little sharp pull no problems :) but when i fitted my replacement grille i found it not so hard to pull off if pulled by the corners what i want to know is could i have fitted it wrong to my car ? and will slightly bending the plastic clips help it any ? thanks. Quote Link to comment Share on other sites More sharing options...
b1g_dav3 Posted July 8, 2012 Share Posted July 8, 2012 Make sure all the clips are in, I had that problem to start with, they're a bit fiddly and a pain but go in easy enough. Quote Link to comment Share on other sites More sharing options...
FIESTA_MAD Posted July 8, 2012 Author Share Posted July 8, 2012 but it sounds like it does clip in just not got any grip at all ? Quote Link to comment Share on other sites More sharing options...
FIESTA_MAD Posted July 9, 2012 Author Share Posted July 9, 2012 should i push it a little more see if it clips in but it does sound like it is cliped in but will try pushing it and if it dont work remove the grille bend the clips and see if it helps. Quote Link to comment Share on other sites More sharing options...
Johnno260 Posted July 9, 2012 Share Posted July 9, 2012 I haven't fitted one yet, but plan to. If you had the chrome surround before, and haven't fitted it to the new one, could that be the reason it's looser? As it looks like a snugger fit. Quote Link to comment Share on other sites More sharing options...
FIESTA_MAD Posted July 9, 2012 Author Share Posted July 9, 2012 It was a like for like swap :) Will sort it at the weekend :) Quote Link to comment Share on other sites More sharing options...
