irl-06lx Posted July 11, 2012 Share Posted July 11, 2012 Hi all, Looking for info as to how the gearstick gaiter on the mk2.5 clips in. I have put one of the arm rests into my mk2 and it works well however I need the below pictured gearstick gaiter (including chrome base surround) Can anyone enlighten me ideally with images as to hwo it clips in and will my console take it? Basically, is there anything car specific about how it clips in or does it clip straight to the console? If it goes straight to the console it should be able to clip in when the console is out, so if it cant then im in trouble. Picture kindly by lenny. The attached picture is what mine looks like. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted July 11, 2012 Share Posted July 11, 2012 The gaiter is removed by prising up with a screwdriver under the back of the trim (side facing the handbrake) and clips back in from the front first. Use tape over the screwdriver to avoid damaging the trim or sandwich the blade between two strips of plastic so that you leave marks on the strips rather than the trim. This image is for removing the gear gaiter from a MK2 but is the same procedure for a MK2.5 Quote Link to comment Share on other sites More sharing options...
ShinyAndy Posted July 12, 2012 Share Posted July 12, 2012 Let me know where you find the gaiter, clips and chrome surround as the surround on mine is broken and everything on eBay seems to only be the leather bit Quote Link to comment Share on other sites More sharing options...
irl-06lx Posted July 12, 2012 Author Share Posted July 12, 2012 I'm getting one from fordpartsuk.com, not cheap about £60 including delivery but cant find one on eBay at all. Stoney the picture you showed is for the mk 2 i believe. Looking at the attached picture in the OP of what mine is like now, does it look like I'm missing anything? Quote Link to comment Share on other sites More sharing options...
ShinyAndy Posted July 12, 2012 Share Posted July 12, 2012 I'm getting one from fordpartsuk.com, not cheap about £60 including delivery I think I'll just glue mine then! Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted July 12, 2012 Share Posted July 12, 2012 I'm getting one from fordpartsuk.com, not cheap about £60 including delivery but cant find one on ebay at all. Stoney the picture you showed is for the mk 2 i believe. Looking at the attached picture in the OP of what mine is like now, does it look like I'm missing anything? As stated, yes it's a mk2 picture but the ring around the gear gaiter is exactly the same on a 2.5. Quote Link to comment Share on other sites More sharing options...
irl-06lx Posted July 12, 2012 Author Share Posted July 12, 2012 ok cool thanks didnt see you stated it my bad. However, the ring around the mk2.5 is slightly bigger as my mk2 gaiter and chrome ring don't fit. Once they clip in the same then happy days Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted July 16, 2012 Share Posted July 16, 2012 Just found the chrome surround off a MK2 available to anyone looking for one.- http://www.ebay.co.uk/itm/FORD-FOCUS-2007-GEAR-COVER-TRIM-5M5P-7J306-A-/160838365994?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2572b6b32a Quote Link to comment Share on other sites More sharing options...
Whoey Posted August 13, 2012 Share Posted August 13, 2012 I'm only really after the plastic bit that's attached to the gaiter, that clips into the surround... my surround is in great shape, the plastic bit not so much... I ordered new leather gaiter and guess I'll have to glue it to the surround... seems to be a common thing that breaks, no wonder they're so expensive! Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted August 13, 2012 Share Posted August 13, 2012 Look at this on eBay: Genuine Ford Focus Mk2 05 Silver/Chrome Look Gaiter Surround (only!) http://bit.ly/Nu8qIV Quote Link to comment Share on other sites More sharing options...
Whoey Posted August 14, 2012 Share Posted August 14, 2012 yup, mine is exactly like that, in perfect condition, it's the inner part that is stapled to the gaiter that is broken. I spent a couple hours yesterday pulling apart my old stock gaiter and hot glued the broken pieces back together, then put my new leather gaiter over it, and mounted it into that surround piece, I drilled 2 small holes on each side from inside to out and put some small computer screws inside to hold the ring in place. it looks great and is very solid now, I don't think it will pop out when changing from 1st to reverse when I'm parking now! Quote Link to comment Share on other sites More sharing options...
ShinyAndy Posted August 14, 2012 Share Posted August 14, 2012 Fancy nipping down to the coast and doing mine? :D Quote Link to comment Share on other sites More sharing options...
Whoey Posted August 14, 2012 Share Posted August 14, 2012 Fancy nipping down to the coast and doing mine? :D it's a bit of a haul to get down there... plus not sure I could handle the heat! Here's a couple quick shots so you can see exactly what I mean: Quote Link to comment Share on other sites More sharing options...
ShinyAndy Posted August 14, 2012 Share Posted August 14, 2012 I'm right near the beach so it's much cooler, only 32ºC here at the moment (unlike inland where it's been in the mid 40's last week) :) Yup, mine has broken exactly the same.. maybe the heat here makes the plastic brittle! Good idea to use the screws to hold it in place Quote Link to comment Share on other sites More sharing options...
rainfallgr Posted June 9, 2015 Share Posted June 9, 2015 ok cool thanks didnt see you stated it my bad. However, the ring around the mk2.5 is slightly bigger as my mk2 gaiter and chrome ring don't fit. Once they clip in the same then happy days Hello , I searching in the net for the PN of this gaiter with the surround and i cannot find anything. could you please give the part number you bought? my surround ring is slightly larger as yours Quote Link to comment Share on other sites More sharing options...
zangaby Posted August 11, 2015 Share Posted August 11, 2015 I'm also looking for this part. Any luck so far ? Unfortunately I couldn't find any PN. The part is relatively cheap pn eBay but there are 2 versions, one for the console with armrest (like the one on the first post) and another one for the one without armrest. Without knowing the PN it's quite hard to order. Quote Link to comment Share on other sites More sharing options...
Titanium06 Posted July 17, 2016 Share Posted July 17, 2016 Hi, can anybody help me please? I'm after a new leather gaiter for a Ford Focus 1.6 TDCI Titanium on a 2010 plate, ford have quoted me £98 plus VAT, which is a more than I'm looking to pay. I've looked on eBay but don't know what I'm looking for that will fit as an alternative, any advice you can offer or links would be really helpful. thanks in advance Sarah Quote Link to comment Share on other sites More sharing options...
