Automatic Headlight Sensor
79 replies to this topic
#31 Haz93
Haz93
    Serial Poster
  • Budding Enthusiast
  • 453 posts
  • Name: Harrison
  • Ford Model: Audi A5 Cabriolet + Mini Cooper
  • Year: 2009
Posted 18 October 2012 - 04:28 PM
Yeah I thought tint wouldn't be too good, from past experiences anyways.
What glue did you use for the sensor mount??
Have something to contribute?
#32 clubber
clubber
  • 109 posts
  • Ford Model: ST3
Posted 18 October 2012 - 04:37 PM
I didn't use glue. I put a big blob of blu tac onto the sensor and stuck it to the mirror casing. As there is not much room for manoeuvre in there the sensor is sandwiched between the windscreen and the casing. It seems to be holding.
Do your wipers come on automatically? My ones have to be woken by moving the scroll wheel. I think the sensor position needs adjusting.
#33 NorthSussex
NorthSussex
  • True Ford Enthusiast
  • 976 posts
  • Name: Stormin
  • Year: 2009
Posted 18 October 2012 - 05:02 PM
If enough rain comes on the windscreen the wipers should come on automatically, if the wiper stalk is in the first position up then they should automatically vary depending on the rain level, also if the stalk is pulled back to set the rear wiper on this will also intermittently wipe and also wipe when reverse is selected.
#34 Haz93
Haz93
    Serial Poster
  • 453 posts
  • Name: Harrison
  • Year: 2009
Posted 18 October 2012 - 05:03 PM
When I first glued the sensor to the screen and all of the sensor was in contact with the glass they worked fine without havering to wake them up :)
As the glue started to come off they needed to be woken, got to the point where it came off completely. I think it had something to do with the heated screen making the glue soft.
Now i have a wodge of aerospace grade tissue :P wedged behind like your bluetac, but i imagine the bluetac is better tbf
I might get some vinyl too as my black paper looks a bit silly ahaha
#35 Brigante
Brigante
    Resident Ranter
  • PipPipPipPipPip
  • 2,983 posts
  • Name: Charlie
  • Ford Model: Mondeo Titan X Sport 2.2 175BHP
Posted 18 October 2012 - 05:14 PM
Sorry lads gotta say again this makes me glad I got the ghia so mine came with as standard.
#36 clubber
clubber
  • 109 posts
  • Ford Model: ST3
Posted 18 October 2012 - 08:37 PM
Did you push the front of the sensor directly onto the windscreen? My sensor isn't touching the screen, I have left a tiny gap. Do you think this is why it doesn't work properly?
#37 Stoney871
Stoney871
    Resident Peacekeeper
  • Super Mod
  • 18,182 posts
  • Name: Clive
  • Year: 2015
Posted 18 October 2012 - 08:46 PM
I seem to recall that on a factory fit there is a small gel spacer between the sensor and the screen.
#38 clubber
clubber
  • 109 posts
  • Ford Model: ST3
Posted 18 October 2012 - 08:54 PM
I have the gel bit on the sensor but is the gel part supposed to actually touch the windscreen?
#39 Haz93
Haz93
    Serial Poster
  • 453 posts
  • Name: Harrison
  • Year: 2009
Posted 18 October 2012 - 09:09 PM
Yeah it's ment to be pushed fully against the screen for the wipers to work. That's why the mount is glued on as it needs to be really strong to hold all the pressure. Also there should be no bubbles or gaps to be most effective
Think I might do a bit of research into windscreen glue :P
#40 clubber
clubber
  • 109 posts
  • Ford Model: ST3
Posted 18 October 2012 - 10:02 PM
When you look at a car that has auto wipers already on it, the sensor doesn't touch the windscreen
#41 Haz93
Haz93
    Serial Poster
  • 453 posts
  • Name: Harrison
  • Year: 2009
Posted 18 October 2012 - 10:25 PM
If its fitted from factory then it may look like I doesn't as it's done very professionally but I guaranty they should be pressed against the window mate
#42 clubber
clubber
  • 109 posts
  • Ford Model: ST3
Posted 19 October 2012 - 06:03 AM
Didn't know that. I will adjust it later and see how it goes.
#43 clubber
clubber
  • 109 posts
  • Ford Model: ST3
Posted 19 October 2012 - 03:55 PM
Adjusted it, a little better now, not perfect though.
#44 k13r4n
k13r4n
  • 747 posts
  • Name: kieran
  • Ford Model: MK7 Fiesta Metal
  • Year: 2011
Posted 19 October 2012 - 05:06 PM
Same here Charlie
#45 clubber
clubber
  • 109 posts
  • Ford Model: ST3
Posted 19 October 2012 - 05:10 PM
Same here Charlie
I have an ST :P
Not what you're looking for?
