* * * * * 1 votes
Footwell Lighting
46 replies to this topic
#16 Jack7
Jack7
  • 142 posts
  • Name: Jack
  • Ford Model: Fiesta TDCi Zetec S
  • Year: 2009
Posted 16 July 2012 - 12:51 PM
Ive got the bulb holders but no wiring etc :( Is it possible to retrofit this or is it too complicated? im a bit of a noob especially with electrics :P
#17 iNath
iNath
    Ford Traitor
  • Super Mod
  • 2,725 posts
  • Name: Nathan
Posted 16 July 2012 - 01:01 PM
You would need to go down the aftermarket route and splice in to existing cables as the official Ford ones are part of the ENTIRE wiring loom behind the dash.
#18 Stoney871
Stoney871
    Resident Lawman
  • Super Mod
  • 8,368 posts
  • Name: Clive
  • Year: 2007
Posted 16 July 2012 - 02:47 PM
Buy bulb holders and wire them to the courtesy light feed via the A pillar.
I've been trying to get around to this job for ages myself and have all the bits to do but time and circumstances have not been right.
Lenny can advise you better as he's the king of lighting.
#19 Lenny
    Resident Sherpa
  • 5,322 posts
Posted 16 July 2012 - 03:09 PM
Buy bulb holders and wire them to the courtesy light feed via the A pillar. I've been trying to get around to this job for ages myself and have all the bits to do but time and circumstances have not been right. Lenny can advise you better as he's the king of lighting.
Thanks stoney, ^_^
For those who have the bulb holders but no power,
they should purchase Qty: 2
of this Cable which would be 4 metres of cable. http://www.ebay.co.u...=item27bd5915eb
cut the existing loom around two inches from the bulb sockets and fit this loom running the two sockets off the one single run of cable then up the A pillar and splice in to the blue and black cables at the rear of the interior light.
Blue = Positive +
Black = Negative -
For those who havent got the footwell light sockets or loom
They need to purchase the sockets to fit the holes which are here http://www.ebay.co.u...=item43ae09c359
plus the cable in the link above too.
finally for both fitments they will require some T10 w5w light bulbs of their choice.
if you also require some rear footwell lighting i can advisee on this too.
i have got Qty 2 of these in red led pods fitted under the front seats of my focus,
one stuck to the top of the footwell blower under each seat facing on to the rear footwells and wired in to the loom of the front footwell lighting.
here are some links to the pods for the rear footwell's.
Be sure to order Qty:2 in order to recieve two of them
Red Pod
http://www.ebay.co.u...=item5181144a64
Blue Pod
http://www.ebay.co.u...=item51811449c8
Green Pod
http://www.ebay.co.u...=item5181144a45
White Pod
http://www.ebay.co.u...=item5181144a85
#20 Hell_Bunny_sXe
Hell_Bunny_sXe
  • 556 posts
  • Name: Allan
  • Ford Model: Fiesta 1.4 TDCi Titanium
  • Year: 2009
Posted 16 July 2012 - 03:56 PM
Thanks stoney, ^_^
Blue = Positive +
Black = Negative -
Red Pod
Blue Pod
Green Pod
White Pod
Any chance you could make a guide (if you haven't already) for the rear footwell lights?
It's a cool mod i'd love to do, and could do if I followed pre-written instructions but not from scratch
*utter electrical div* :blink: :unsure: :wacko:
#21 Lenny
    Resident Sherpa
  • 5,322 posts
Posted 16 July 2012 - 04:04 PM
No problem mate,
ill be oline later around 8pm and i will respod to this topic with a written guide including pictures for the wiring of rear footwell lighting using the above equipment.
#22 Hell_Bunny_sXe
Hell_Bunny_sXe
  • 556 posts
  • Name: Allan
  • Year: 2009
Posted 16 July 2012 - 04:15 PM
No problem mate,
Woo! Lenny is the Electrical Man!
#23 Kieatky
Kieatky
    Member
  • PipPip
  • 10 posts
  • Name: kieron
  • Ford Model: fiesta zetec s
  • Year: 2011
Posted 16 July 2012 - 05:02 PM
Hi guys, just thought I'd say thanks for highlighting this topic, didn't have a clue the footwell lights were there, checked my car and found the holders/wiring then out of curiosity borrowed the bulb from the boot courtesy light just to check if they work and hey presto... we have light!!! Well chuffed. Just gotta decide what colour bulbs to order!!! Once again, many thanks.
#24 2011fiesta
2011fiesta
  • 1,526 posts
  • Name: Paul
  • Year: 2011
Posted 16 July 2012 - 05:33 PM
Go for blue Kieron.
Cool, modern, chilled out :D
Paul :)
#25 Kieatky
Kieatky
    Member
  • PipPip
  • 10 posts
  • Name: kieron
  • Year: 2011
Posted 16 July 2012 - 06:12 PM
Cheers mate, I agree, the blue looks good and i think it'll be a better match for the illumination on the sony head unit.
#26 GJC
GJC
  • 146 posts
  • Name: Gavin
  • Ford Model: Fiesta Econetic
Posted 16 July 2012 - 06:15 PM
Go for blue Kieron.
Or Red as it matches the dash/ instrument backlighting...
Nathan posted images of his red ones before and the fact the colours are a match makes it look more factory fitted.
#27 b1g_dav3
b1g_dav3
  • 1,693 posts
  • Name: David
  • Year: 2013
Posted 16 July 2012 - 06:33 PM
Any way of making it so that the lights stay constantly on without tons of effort?
#28 Lenny
    Resident Sherpa
  • 5,322 posts
Posted 16 July 2012 - 06:42 PM
yes just link them to a rocker switch,
and from the switch to an interior light feed,
so then when your driving lights are on i.e. Parking lights etc.
you can switch the footwell lights on and off via the rocker switch, ideal for approaching a check point etc. because the cops may class them as distracting.
but the added advantage of hooking them to an interior light feed is that they will also dim when you turn the wheel to dim your interior dash lighting.
but
if you want them to illuminate along with the doors opening, and then again when you switch on your driving lights.
this would require you to fit a 3way rocker switch then you could use the one set of units for both actions.
#29 Lenny
    Resident Sherpa
  • 5,322 posts
Posted 16 July 2012 - 08:07 PM
Here is a guide on fitting the led pods to the rear footwells in your ford.
you will require in this guide you will notice i have fitted some 3 led pods and the ones linked in the post above are 5 led their isint really much difference in the additional two leds under the footwell but i reckon the 5 led pods would give a slightly better effect.
as you can see in the image below,
the pods come from the supplier pre-wired with red and black terminals on the ends and 1.5metre of cable attached.
i found the casing of the pods to be quite shiny and i wrapped them in a layer of black electrical tape to help keep them hidden under the rear footwells and not really noticable unless they are illuminated.
first step:
strip the ends of both red and black terminals on the end of both units and splice them togeather with one ond of the purchased 2 metre red&black 10amp cable. join the 3 black feeds to each other and tape them togeather using the purchased e;ectrical tape followed by performing the same action with the 3 red terminals. then tape the two bulk insulated cables togeather to create a Y shaped loom, ensure the red and black feeds are insulated seperatly before taping them togeather as one loom.
if desired you can wrap the surround of the pods in black tape too, then fit one or two double sided sticky pads to one side of each pod.
once complete,
you can then bring the new wired loom with pods attached in to the car.
un-bolt the centre console so as it can be lifted up to fit you hand underneath it,
then begin to fish the cables under the seats on both sides ensuring that they are under the slide rails of the seats,
leave around 2 inches of excess cable encase the units ever get caught on anything the cable is not likely to snap if their is a slight bit of excess their to allow for stretching, for example of a small umbrella was to be pulled from under the seat and it caught on the loom of the footwell light pod.
do not stick the pods to the top of the rear footwell heater blowers yet because they may tear off with the fishing of the cables,
wait to mount them correctly at the end of the process.
next step is to locate the front footwell loom cables on the passenger side footwell,
fish your rear footwell loom in to the front of the passenger footwell through the centre console.
cut the excess cable from the rear footwell loom then like pealing a Banna.
using your stanley blade gently peal back the positive feed on the existing front footwell loom feed.
peel back the sleeving to reveal the copper internal and wrap the red positive around the front footwell stripped positive feed then tape it up with some electrical tape,
and repeat the process for the negative feed.
the front footwell loom cables should be Orange and Black
so splice Red to Orange and Black to Black. ensure to do them one at a time because if the terminals meet then the fuse will blow and you may also need to get the code for the stereo so please ensure not to strip the two terminals at the same time. only stip one then tape it up before stripping the second one.
finally the led pods in the rear will be illuminated if this guide was followed correctly.
and you can position the as required while sticking the other sides of the double sided pads to the tops of the rear footwell blowers.
the rear footwell lights will operate exactly the same and fade in and out in time with the front footwell lighting.
im going to make a PDF version of this now too for others to download and print if required.
#30 Hell_Bunny_sXe
Hell_Bunny_sXe
  • 556 posts
  • Name: Allan
  • Year: 2009
Posted 16 July 2012 - 08:16 PM
you will require
first step:
once complete,
Awesome, I'm defo gonna give this some serious thought, looks like a simple electrical splice even I can do!
Danké muchly!
