Fearl3SS Posted July 18, 2012 Share Posted July 18, 2012 Hi guy's. I have this issue on my Fiesta 2006 Ghia, that after fueling up, it will not start, push starting works. After that, driving a few KM/Miles. switch it off and on again, it wont start. I bought the Car Secondhand. and it seems like the workshop that the car is sent to, does not have a clue what they are doing, if they are doing anything at all. Has anyone else come accross this issue before. Quote Link to comment Share on other sites More sharing options...
stef123 Posted July 18, 2012 Share Posted July 18, 2012 does the engine turn over when you turn the key or does it just click? Quote Link to comment Share on other sites More sharing options...
iNath Posted July 19, 2012 Share Posted July 19, 2012 I see no guide here! Moved to correct forum ;) Quote Link to comment Share on other sites More sharing options...
Fearl3SS Posted July 19, 2012 Author Share Posted July 19, 2012 The engin turns.. Sounds like it is not getting any fuel. Push starting works. (but that is not the way to drive away from a filling station). After about 15 min it will start.. after I have switched off everything that could draw power and locked and unlock the car.. Quote Link to comment Share on other sites More sharing options...
Fearl3SS Posted July 20, 2012 Author Share Posted July 20, 2012 Ok, So this morning, I actually recieved a error on the computer : EAC Fail. Doing some research it is the Electronic Accellerator control that is causing the problem. Will take the car in tommorrow to have it checked out for the error code. Quote Link to comment Share on other sites More sharing options...
Fearl3SS Posted July 23, 2012 Author Share Posted July 23, 2012 Update on the issue.. Diag has been run on the car. And a multitude of errors was shown. Majority of the errors indicated over or under Voltage. the Altinator seems to be the cause of all the electrical problems on the car. An order has been placed with FORD for a new altinator. Quote Link to comment Share on other sites More sharing options...
