martync Posted July 24, 2012 Share Posted July 24, 2012 Just had a new set of front discs and pads fitted and tyres which were balanced when put onand also replaced a worn track rod end,but there seems to be vibration still at about 50 to 60 mph the only thing I've not had done is wheel alignment could this be the reason or could it be a worn bush elsewhere its doing my head in anyone have any ideas on this a friend of mine said I could have a buckled wheel and that I should change the front wheels with the back to see if it is a buckled wheel any suggestions guys Quote Link to comment Share on other sites More sharing options...
btmaldon Posted July 24, 2012 Share Posted July 24, 2012 Still sounds like the wheel balancing on the front. The only other thing I have experienced in the past is where a new tyre was slightly out of shape. If the wheel was buckled they should have told you. If its only slight they can balance it out, Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted July 24, 2012 Share Posted July 24, 2012 They would have spotted a buckle when balancing the wheels. Quote Link to comment Share on other sites More sharing options...
