Sign in to follow this
Followers 0
SmokesBoy
New Project For Mk6
5 posts in this topic
Hey
i am recently purchasing a mk6 fiesta.....its basically a shell as it needs new engine...
its originally had a 1.25 inside, however will a 1.4 zetec easily slot in?
Also i previously own a set of 17" ripspeed alloys will they rub on the arches of will they be a neat fit?
Bi Xenon headlights? worth a purchase?
Cheers
Smokesboy
first of all welcome:D
im not too sure about the engine as thats to technical for me, but the alloys should be fine, i have some 205/40/17 zcv alloys on mine and dont rub,
and as for the light bulbs again not sure but think they will.... i have just purchased 2 Canbus T10 194 168 W5W 501 5050 5 SMD LED White Car Side Light bulbs,
ebay number 290654204058
which have had v.god reviews
i hope this is usefull
Thanks mate does help a lot seeing as I prob won't need a new set of alloys now!
ah thats good then:D money saved eh:D
the engine will fit in no bother and run fine also with all the same sensors etc but you wont see much gain out of it unless you get a 1.4 ecu to run it also.,,
all those engines are the same aslone as they are the black rocker cover, ive recently put a 1.6 focus engine into a 1.4 ghia because i didnt have any 1.4's left, and left it runing from the 1.4 ecu.. run alot quicker but if i had have got a zs fiesta ecu it would have all the potensal.
personally id put a 16 into it as it wont be of any or much of a differnt cost and then hunt the breakers and get a zetec s key ecu and clocks and give it a proper upgrade as it will run with the same wiring loom.
Followers 0
