craighuttonn Posted July 29, 2012 Share Posted July 29, 2012 I recently bought my Fiesta MK6 2008! I have an EDGE sub woofer with built in amp from my old car and wish to fit it to the Fiesta, can I do this and keep my standard stereo? Everywhere I have been gives me a different answer! HELP! Quote Link to comment Share on other sites More sharing options...
SteveLake Posted August 28, 2012 Share Posted August 28, 2012 I notice this went unanswered but i had a an edge subwoofer active enclosure wired to a mk7 fiesta and it was wired up to the stock stereo it worked fine but two weeks after it just suddenly stopped working. Before i did get it wired up another place i visited to get it wired refused as it 'was too much of a problem' unless i bought an aftermarket stereo, don't know if the post was of help or if its too late. Quote Link to comment Share on other sites More sharing options...
arronb88 Posted February 2, 2013 Share Posted February 2, 2013 Im haven the same problem did you manage to get it resolved ? Quote Link to comment Share on other sites More sharing options...
FOCA Posted February 2, 2013 Share Posted February 2, 2013 A subwoofer can be connected to any stereo even if it does not have a pre-out you can get an adaptor that connects to the speaker outputs (Speakers still work as normal) the output of the adaptor connects to the input of the subwoofer amp via a long, screened/ coxial cable if the stereo/ head unit has a pre(sub) out, this connects to the input of the sub amp (this is better for sound) the sub amp is powered with a wire direct to the battery via an in-line fuse close to the battery - there may also be another wire that connects to the + that switches the sub amp off/ on, this should be connected to the head unit power output (to switch the sub amp off/ on ) Quote Link to comment Share on other sites More sharing options...
