WhyDelilah Posted August 2, 2012 Share Posted August 2, 2012 Hi all, I'm new to the forum and I'm after a bit of help. My Ford Fiesta Finesse is due in for its MOT next month and I have a couple of problems I'd like to sort before taking it in. The first problem is, the horn has decided to stop working. Is this something easily fixable (i.e. can I do it myself?)? Is it just something as simple as replacing a fuse?? The second problem is, the driver seat no longer folds forward to allow access to the back seats (3 door car). When you pull the handle to push the chair forward it is just not working anymore. Any idea how big of a job it is to fix that, or if I can do it myself??The first problem is, the horn has decided to stop working. Is this something easily fixable (i.e. can I do it myself?)? Is it just something as simple as replacing a fuse?? The second problem is the driver seat no longer folds forward to allow access to the back seats (3 door car). When you pull the handle to push the chair forward it is just not working anymore. Any idea how big of a job it is to fix that, or if I can do it myself?? Many thanks for any help you can give. WD Quote Link to comment Share on other sites More sharing options...
sambooka Posted August 2, 2012 Share Posted August 2, 2012 Hi all, I'm new to the forum and I'm after a bit of help. My Ford Fiesta Finesse is due in for its MOT next month and I have a couple of problems I'd like to sort before taking it in. The first problem is, the horn has decided to stop working. Is this something easily fixable (i.e. can I do it myself?)? Is it just something as simple as replacing a fuse?? The second problem is, the driver seat no longer folds forward to allow access to the back seats (3 door car). When you pull the handle to push the chair forward it is just not working anymore. Any idea how big of a job it is to fix that, or if I can do it myself??The first problem is, the horn has decided to stop working. Is this something easily fixable (i.e. can I do it myself?)? Is it just something as simple as replacing a fuse?? The second problem is the driver seat no longer folds forward to allow access to the back seats (3 door car). When you pull the handle to push the chair forward it is just not working anymore. Any idea how big of a job it is to fix that, or if I can do it myself?? Many thanks for any help you can give. WD In response to the second problem the cable in the seat has probably snapped not sure if they can be replaced or repaired as I've not had one go (touching wood) The horn problem i would guess either fuse of the horn itself if you have access to a multimeter of know someone who does you should be able to sort it Quote Link to comment Share on other sites More sharing options...
