Snow Foam
#1
Posted 03 August 2012 - 04:28 PM
#2
Posted 03 August 2012 - 08:35 PM
What you need:
The car foamed:
The results - You can also wash the car after but I didn't feel the need to
Ps Ignore the tyres I did put some tyre gel on them
#3
Posted 03 August 2012 - 08:50 PM
I use AutoBrite's Magifoam and would really recommend it. It's fun to use and has great results. It's nice and thick and clings to the car for a very long time.
What you need:
The car foamed:
That looks so easy that even I could do it!
#4
Posted 03 August 2012 - 08:52 PM
#5
Posted 03 August 2012 - 09:18 PM
It is super easy! You fit that bottle known as a lance to a pressure washer and spray away. Go away, have a drink or something for 15 mins. Come back and wash off the foam with the pressure washer. Dry the car and you're done!
ditto..
ive usd bilt hamber as well, loads of info on detailingworld
#6
Posted 03 August 2012 - 09:42 PM
#7
Posted 04 August 2012 - 03:47 PM
What is the cost of the snow foam you use,5 ltr by the looks.
So if I am correct you don't have to agitate the foam after 15 mins with a wash mitt to remove any surface dirt?
#8
Posted 04 August 2012 - 04:19 PM
I guess over time it makes for a good deal as you'll only ever need one lance.
Also it's as simple as spray on and spray off, you put about 2 inches in the lance and fill the rest with warm water. If you're car is particularly dirty you can also add a small amount of car shampoo for extra strength.
There is no contact needed with the car to snow foam as its known as a pre wash stage ie you foam it then clean it as the foam removes the contamination and when you sponge/mitt wash it there is no dirt to swirl the paint - if that makes sense?
I just usually snow foam on its own though. The weather isn't great to fully wash a car and it's especially good for quick washes in the winter
#9
Posted 05 August 2012 - 07:58 AM
#10
Posted 05 August 2012 - 09:18 AM
Looks good, but you could never beat 3 hot bikini clad girls washing your car with lots of foamy car shampoo!
The scratches, the scratches!
#11
Posted 05 August 2012 - 10:33 AM
Its a prewash so the idea is you foam the car, let it dwell 5 minutes then rinse off. You can the wash the car as normal with 2 buckets (one for soap and one for rinsing) and wash mitts. Foaming first removes the worst of the muck and reduces the chances of scratching the paint when using the mitts. Its also really handy in the winter for just giving the car a quick wash to remove the worst of the salt and grime. Just be sure to avoid foams which strip wax.So if I am correct you don't have to agitate the foam after 15 mins with a wash mitt to remove any surface dirt?
Best of both worlds?Looks good, but you could never beat 3 hot bikini clad girls washing your car with lots of foamy car shampoo!
Credit: AutobriteDirect who also do foaming lances and foames: http://www.autobrite...foam-combo.html
#12
Posted 05 August 2012 - 11:02 AM
#13
Posted 05 August 2012 - 11:09 AM
This has caused some debate before - but in my opinion the suds of snow foam should be so thick and heavy that the action of them rolling off the car takes the dirt off the car. If you want a prewash to just loosen dirt, buy a prewash, that's not what snow foam is designed for.
#14
Posted 05 August 2012 - 03:18 PM
Just use the picture for effect
#15
Posted 05 August 2012 - 03:22 PM
