giorgi
Hi New To The Forum Need Help!
5 posts in this topic
i have a 2009 ford fiesta edge, i turned the radio on the other day an i could barely hear it i usually have it on 8 an its quite loud but now on 30 i can barely hear it. i took it to my local mechanic an he basically said he dont know an to take it back to ford but my warranty has run out or to a radio specialist but i dont wanna get rip off because i dont know much about cars
Welcome to the Forum.
Bit of a long shot, Try disconnecting the battery, and then reconnect it and re-enter the radio code, hopefully this will re-set the radio.
FYI there's no radio code to enter on the current shape Fiesta.
pull the head unit out its usualy on the back if not look in your radio manual it may be in there some even come with a radio key card with it on good look if not it will need to be re-coded
check the simple things, make sure that your balance and faders are all on 0 or positive numbers, if they are all set to negative numbers, that would massively reduce the volume
