I have an 05 Ford Focus 1.6 TDCi which has done 130K. I have recently noticed a noise whenever I put any pressure at all towards the left on my steering wheel. The noise continues until the pressure on the wheel is released. It's difficult to describe the noise but a low pitched hum would probably be close.
I don't want to go to a dealer witghout having some idea of what the problem could be so could anyone point me in the right direction.
Steering / Suspension / Bearings Concerns.
Started by ixxy, Aug 06 2012 04:21 PM
steering suspension bearings
2 replies to this topic
#1
Posted 06 August 2012 - 04:21 PM
#2
Posted 06 August 2012 - 06:33 PM
Easy fix?
Go the long way round and turn right only?
#3
Posted 06 August 2012 - 08:42 PM
A few things to try and diagnose the possible problems:
Does the car stay straight and true when driving?
What about when braking?
Jack the car up and spin the wheels with your hands. If it's bearings you'll hear them - a rough, dry scraping noise. No noise = good bearings.
Then with the car still up on the jack, put your hands on the wheel/tyre at 12 o'clock and 6 o'clock and try and rock the wheel backwards and forwards. Repeat with your hands at 3 o'clock and 9 o'clock. This will help to diagnose worn/loose bushes or track rod ends - if nothing moves then they should be OK.
Failing that, go to a garage and get them to put it on the ramps. Steering and suspension is critical to safe handling & braking, so you don't want to take any chances. An inspection should be cheap or even free.
Also tagged with one or more of these keywords: steering, suspension, bearings
United Kingdom - General Ford Discussions by Model →
Ford Mondeo Club →
05 Mondeo Dodgy Steering IssuesStarted by zetec4, 02 May 2013 |
Ford Focus Club →
Guide PricesStarted by nuttyamy, 29 Apr 2013 |
Ford Focus Club →
Suspension BushesStarted by Dan9014, 18 Mar 2013 |
Ford Focus Club →
Weird Steering Issue In My FocusStarted by delta-delta, 29 Jan 2013 |
Ford Focus Club →
02 Focus Tdci Pas Not Working At IdleStarted by Rob Bowes, 24 Jan 2013 |
