Glow Plugs
6 replies to this topic
#1 amgg
amgg
    Newbie
  • New Member
  • Pip
  • 1 posts
  • Ford Model: ford focus 1.6tdci zetec 4door hatchback
Posted 07 August 2012 - 01:58 AM
engine manegment light was on glow plug circuit A malfunction..
So changed glow plugs and 1 glow plug broke inside while onscrewing the glow plugs out but the tip of the glow plug is still in the head a little bit.
So the mechanic put in 3 remaing glow plugs in and connected
The fourth glow plug wire on to the 3rd glow plug so he can bypass the engine manegment light wich has worked and limp mode is off but the broken glow plug is still in there i was told to drive it so it will shoot out. .any sugestions. Can this damage my enginge is the glow plug whole in the cylinder head smaller then the glow plug. . Please help
Have something to contribute?
#2 artscot79
artscot79
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 8,006 posts
  • Name: arthur
  • Year: 2006
Posted 07 August 2012 - 05:43 AM
thats not good it depends on the design of the plug some have a collar that stops it slipping into the head some dont.
the mechanic should be shot there can be 400 psi in there if the compression did shoot it out while the engines running and bonnet closed it would blow a hole right through it as it will shoot out like a bullet if the bonnets open stay way clear ive seen one go halfway into a thick piece of wood when it was blown out if that was youre head in the way nite nite vienna if the plug doesnt have a collar it can slip into the engine and knacker it the mechanic sounds shoddy thats not the kind of advice to give if its not retrievable with long nose pliers then its advised to have the head removed im afraid theres no point leaving it the 3rd plug will burn out quicker and youll still have the same issue
#3 mintalkin
mintalkin
  • PipPipPipPipPip
  • 3,560 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 07 August 2012 - 05:24 PM
drive it untill it blows out, is he for real, where does he work, bodge it and scarpa
#4 Stoney871
Stoney871
    Resident Peacekeeper
  • Super Mod
  • 18,601 posts
  • Name: Clive
  • Year: 2015
Posted 07 August 2012 - 06:59 PM
Head off, tap the plug tip out of the hole.
Leaving it as it is will be very dangerous.
#5 Pitmonster
Pitmonster
  • New Member
  • 350 posts
  • Name: Dave
  • Ford Model: 2006 Mk2 Focus 1.8 TDCi Zetec (Climate)
  • Year: 2006
Posted 07 August 2012 - 07:27 PM
Sorry for asking, because this isn't clear to me from the opening post - but who actually removed the old glow plugs (leaving half a plug in there)?
You or the mechanic?
If it was the mechanic, doesn't he have liability to put it right at his cost?
#6 artscot79
artscot79
  • PipPipPipPipPip
  • 8,006 posts
  • Name: arthur
  • Year: 2006
Posted 07 August 2012 - 11:23 PM
glow plugs on most cars are notorious for snapping which is why a decent mechanic would soak them first then loosen them slowly unfortunately you have the expense of having the head removed the glow plug extracted a new head gasket and coolant and all bolted back together
#7 stef123
stef123
  • Management
  • 5,872 posts
  • Name: Stefan
  • Ford Model: Mondeo ST TDCI
  • Year: 2006
Posted 08 August 2012 - 06:20 PM
a professional mechanic 'with all the tools' will have a piece of kit that vibrates and uses low torque to remove stubborn plugs.
using a ratchet and socket however, there is always the risk they will snap.
Not what you're looking for?
