Guide To Fixing Common Focus Bonnet Lock Problem.
152 replies to this topic
#46 Ross_Garland
Ross_Garland
    Newbie
  • Members via FB
  • Pip
  • 5 posts
  • Name: Ross
  • Ford Model: Focus Sport
  • Year: 2006
Posted 25 October 2013 - 07:51 AM
I've just bought a 56 plate 1.8 TDCI focus sport and have this problem.  When shpwing me around the car, the owner managed to open the bonnet no problem, but since taking it home, I've not been able to open it!
I've tried to follow this guide - I've managed to get the rubber boot, get a screw driver into the white collet and give it a good old push, but nothing.
Maybe I'm not pushing on it hard enough?  How hard to i physically need to put into it?  What are my options if I can't get this off?  Am I gonna have to smash in the grill to open the bonnet, or is it gonna be a costly garage fee?
Cheers!
Have something to contribute?
#47 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 19,766 posts
  • Name: James
  • Year: 2007
Posted 25 October 2013 - 08:46 AM
When you try the key, do you feel any resistance at the key?
I find that I need to press down on the bonnet, above the catch when turning the key Left, in order to engage the click that opens the bonnet, then turning right allows the full unlock.
Does this make a difference?
#48 Stoney871
Stoney871
    Resident Peacekeeper
  • Super Mod
  • 16,958 posts
  • Name: Clive
  • Year: 2015
Posted 25 October 2013 - 09:20 AM
I always push the bonnet down to put less strain on the key and lock.
#49 Ross_Garland
Ross_Garland
    Newbie
  • Members via FB
  • Pip
  • 5 posts
  • Name: Ross
  • Year: 2006
Posted 25 October 2013 - 11:48 AM
I'm not sure whether there is any resistance when I turn the key left - I don't think so... However, it's still clicking and I can feel resistance when I turn the key right.
I've just tried to open it by applying some pressure to the bonnet, and again, no luck opening it :(!
#50 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 19,766 posts
  • Name: James
  • Year: 2007
Posted 25 October 2013 - 01:02 PM
this is where you need a thousand hands.
You need to apply a very firm pressure to the bonnet as you are about to turn the key. You also need to apply a very firm pressure to a screwdriver against the white collar of the barrel. Both of these should allow you to pop the bonnet, and I would suggest from thereon, you close the bonnet just so that it cant be opened, but isnt locked, and you then replace the kit at your earliest chance.
#51 Ross_Garland
Ross_Garland
    Newbie
  • Members via FB
  • Pip
  • 5 posts
  • Name: Ross
  • Year: 2006
Posted 25 October 2013 - 01:14 PM
I'll give this a bash when I get home!  Where about on the bonnet am I wanting to apply the pressure?  Just above the grill, or above the locking mechanism etc?
Also, where about should I be 'aiming' the screwdriver into the white collet?  I know it said on this guide to have it above the cable, but I saw on another guide that you want to just get it into one of the holes.
Cheers!
#52 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 19,766 posts
  • Name: James
  • Year: 2007
Posted 25 October 2013 - 01:29 PM
Press down on the catch area directly above where the catch is, so about 3 inches in from the bonnet lip in line with the key. Press down firmly as you turn the key.
The best place to get the screwdriver is directly above as then the pressure spreads around the collet and eases the pressure everywhere. Only try to get it in anywhere if you really cant get it above, otherwise if you put pressure on a weaker side and fracture the collet, your options dwindle to a dealer and a massive repair bill!
#53 Ross_Garland
Ross_Garland
    Newbie
  • Members via FB
  • Pip
  • 5 posts
  • Name: Ross
  • Year: 2006
Posted 25 October 2013 - 03:39 PM
Just tried that, again, no luck :(...
#54 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 19,766 posts
  • Name: James
  • Year: 2007
Posted 25 October 2013 - 04:25 PM
if it really doesnt work and you have got the perfect pressure on it, then its likely you will need to go destructive :(
#55 vince_13
vince_13
    Vince
  • True Ford Enthusiast
  • 542 posts
  • Name: Andrew
  • Ford Model: Focus Zetec
  • Year: 2009
Posted 25 October 2013 - 08:05 PM
i didn't need to put any pressure on the bonnet, what I would suggest is to rotate the screwdriver around the white collar whilst hitting it, hit the top then the bottom, then the right side then the left etc
#56 Ross_Garland
Ross_Garland
    Newbie
  • Members via FB
  • Pip
  • 5 posts
  • Name: Ross
  • Year: 2006
Posted 26 October 2013 - 11:28 AM
Great news :D!  I've managed to get the bonnet open.  I had to lightly bounce the bonnet (just above the lock), whilst turning the key right, and then all the way left.
When the bonnet was opened, I used to a screwdriver to make the mechanism 'think' I had closed the bonnet, I then tried to 'unlock' it normally, and it worked perfectly under these circumstances.  However, whenever I added some weight (trying to replicate the weight of the bonnet), or even closed the bonnet, the mechanism wouldn't work...
Just made me wonder whether this a problem with the lock or the catch?  I should also note that the mechanism is quite clunky it actually works, is this normal?
Cheers :)
#57 STEADS
STEADS
  • PipPipPipPipPip
  • 1,068 posts
  • Name: NEIL
  • Ford Model: FOCUS 1.8 TDCI TITANIUM AND 2.0 TDCI
  • Year: 2009
Posted 27 October 2013 - 05:14 PM
Not sure if there are two rubbers either side of the slam panel you can adjust
#58 Carl0s
Carl0s
  • Budding Enthusiast
  • 117 posts
  • Name: Carl
  • Ford Model: Mondeo MK4
  • Year: 2006
Posted 28 October 2013 - 09:28 AM
Just a headsup.. If / when you get your hood open, remove the 2 screws that keep the grill on. After that the grill is hold in its place anly by few clips. Thisway, if the unlock mechanism starts to give trouble, jou can simply pull the grill off whitout braking anything, and operate the lock.
#59 Paulie
Paulie
    Member
  • PipPip
  • 11 posts
  • Name: Paul
  • Ford Model: Zetec 110bhp
  • Year: 2009
Posted 08 December 2013 - 09:10 PM
Unbelieveable, I changed the grill and removed the two headlights to clean this morning and then had realised i couldn't open the bonnet so i couldn't drive the car with the two headlights missing. Anyhow, I have just tried to open bonnet with your advice (in the dark) and after 5 minutes you saved my bacon, as the missus wasn't looking forward to walking! Thankyou, Brill job
#60 shamus1
shamus1
  • 114 posts
  • Name: shane
  • Ford Model: focus titanium 2.0 tdci
  • Year: 2005
Posted 09 December 2013 - 05:44 PM
I had the dreaded problem and followed guide and cut the 2 white tabs off and perfect so thanks very much for the guide.
Not what you're looking for?
15 user(s) are reading this topic
0 members, 15 guests, 0 anonymous users
