Guide To Fixing Common Focus Bonnet Lock Problem.
165 replies to this topic
#106 wobbo
wobbo
    Newbie
  • Budding Enthusiast
  • Pip
  • 4 posts
  • Name: stuart
  • Ford Model: 1.6 climate
  • Year: 2007
Posted 15 June 2014 - 02:47 PM
yeah we had some long drivers, its the angle thats the prob, going to try again,
Have something to contribute?
#107 stebo88
stebo88
    Member
  • PipPip
  • 12 posts
  • Name: stephen
  • Ford Model: focus
  • Year: 2007
Posted 19 June 2014 - 05:39 PM
I have the same problem with my 07 focus. When the bonnet is down it is a nightmare to open again but once its open the mechanism works fine. Can it be fixed? Everytime i need to get into me bonnet it takes ages to get it open and is very frustrating.
#108 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,977 posts
  • Name: James
  • Year: 2007
Posted 19 June 2014 - 06:26 PM
push down on the bonnet above the catch, this helps to take the pressure off and makes it easier to open. I would suggest that you buy the replacement kit and get it done next time you get the bonnet open, to prevent you from getting it closed once and for all!
#109 JAL
JAL
    Newbie
  • New Member
  • Pip
  • 1 posts
  • Name: John
  • Ford Model: Focus 1.8L Diesel Estate
  • Year: 2004
Posted 06 July 2014 - 09:20 AM
Hi Guys, I'm the latest  member to join, and I'm hoping someone can help me.  I've read with great interest the posts regarding
opening the Focus bonnet, but there's no bowden cable or white collar visible through the plastic grill on my car, the model is 2004 1.8L estate diesel, the key and 2 spares refuse to move either way.  I need to gain access to hydraulic reservoir to bleed brakes,so it's rather urgent, local Ford dealer estimated £150!
I'll be really greatful if any member can help, Thanks in anticipation.
JAL
#110 Crinkmeister
Crinkmeister
    Newbie
  • Pip
  • 7 posts
  • Name: Mike
  • Ford Model: Focus
  • Year: 2007
Posted 06 July 2014 - 12:01 PM
There has to be another way of opening this STUPID bonnet!! I have just spent  over 2 hours trying to open an 07 plate Focus bonnet. I've had long thin screwdrivers, shorter fatter screwdrivers, I've pushed as hard as I can on top, left, right, bottom, top again and again and again..... Turning key, pushing bonnet down, bouncing bonnet, pushing key, not pushing key, two pairs of hands and not so much as a click. Now I'm a confident DIYer and a reasonable home mechanic but this has to be THE MOST IDIOTIC design for a bonnet catch!!! What total numbskull came up with this? Do I need to rip the grill out to get to the release? Sorry for the rant - I'm just a little p***ed off with it right now. I'll go and get a Snickers...
#111 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,977 posts
  • Name: James
  • Year: 2007
Posted 06 July 2014 - 03:20 PM
It's tricky but sometimes biting the bullet is the easiest answer. If you have put the pressure all around and pushed on the bonnet while turning the key then there is not much more to do other than repeat the efforts
Sent from my MY SAGA C2 using Ford OC mobile app
#112 Bristolben
Bristolben
    Newbie
  • New Member
  • Pip
  • 1 posts
  • Name: Ben
  • Ford Model: Focus
  • Year: 2005
Posted 07 July 2014 - 10:09 PM
I'm another victim of this problem but I maybe in deep trouble. I managed to pop the lower part of the grill off and noticed the end of the plastic catch had snapped. I then tried to twist the catch to see if the bonnet would open but the piece came off in my hand so I am now unsure if I can open the bonnet by removing the rubber bung and applying pressure with a screw driver? :(
#113 Crinkmeister
Crinkmeister
    Newbie
  • Pip
  • 7 posts
  • Name: Mike
  • Ford Model: Focus
  • Year: 2007
Posted 08 July 2014 - 06:48 PM
Could anyone please describe the next, more destructive, step to opening this bonnet? I assume that I am going to have to replace the grill, so once through there, am I drilling out fixing bolts or does it involve more work on the white plastic collet or the cable?
#114 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,977 posts
  • Name: James
  • Year: 2007
Posted 08 July 2014 - 08:02 PM
I would price up a new bonnet, perhaps an angle grinder around the joint could work.
I would say dont, just take it to Ford and leave it to be their problem. It will be a damned site cheaper in the long run!
#115 Crinkmeister
Crinkmeister
    Newbie
  • Pip
  • 7 posts
  • Name: Mike
  • Ford Model: Focus
  • Year: 2007
Posted 16 July 2014 - 10:10 PM
OK. Here's my solution: Buy a replacement grill from ECP and a bonnet lock repair kit from your friendly local Ford dealer. While you're at the Ford dealer, ask the very helpful service manager how to get the ****ing bonnet open. Listen very carefully to what he says, follow his advice, and after an hour or so working through the hole in the grill that you neatly made with your multi-tool, you will be able to access the white cross shaped coupler that you need to turn with some long nose pliers or (as in my case) a wedged-on box spanner to open the bonnet. When the stupid thing is open, rejoice quietly and repeat "well, that wasn't so bad" many times until you believe it. Remove your existing lock barrel by pushing out the long rollpin and sawing across the top of the two short ones until you can fish them out. Insert old lock barrel into new cable assembly and secure with rollpins from the kit. Undo two 10mm bolts that hold lock mechanism and remove. Pull out old cross coupler and any remnants of the old white plaastic housing and connect the new cable. Poke through hole and refit bolts. Assemble and fit new grill and push lock barrel into its locating slot, ensuring that plastic catches hold it in place. Check many many times to the point of onset of OCD that the key now operates the lock mechanism BEFORE CLOSING THE BONNET!!!!! Carfefully close bonnet with a firm push - don't drop it down. I can't pretend it was easy, but should only take half a day for a first attempt. I should be quicker next time................
#116 littletel
littletel
    Newbie
  • 2 posts
  • Name: Terry
  • Ford Model: Focus
  • Year: 2007
Posted 25 September 2014 - 07:01 PM
Excellent guides. I tried all the suggestions on this site as the bonnet on my 2006 Focus also wouldn't open. Unfortunately none worked for me so I took it to a local mechanic. He removed the grille by lifting the bonnet slightly to get to the plastic screw in plugs that hold it in place. They are located at the top corners of the grille and can be levered out, gently to avoid breaking them. The lock can then be removed. The reason the solutions on here didn't work for me is because the cable connecting the key barrel to the locking mechanism had stretched or perished enough for it not to be tight enough to unlock the bonnet. With the whole lock removed you could see the key turning the 'male' connector but if you held the connector you could still turn the key. In my situation I need a whole new lock. Don't tell any car thieves! but I opted for the quick fix of leaving the lock off the car and using a flat head screwdriver, pushed through the space left by removing the barrel, pushed into the 'female' connector to turn it left then right (as the key would normally do). My key to unlock the bonnet is a screwdriver for now!
Apologises if I've posted (by mistake) another version of my experience.
#117 ggsouth
ggsouth
    Newbie
  • New Member
  • Pip
  • 1 posts
  • Name: Garth
  • Ford Model: Focus
  • Year: 2007
Posted 26 September 2014 - 12:16 AM
Great guide mate. However, the photos don't show up :-(
#118 texas
texas
    Newbie
  • New Member
  • Pip
  • 1 posts
  • Name: Stephen
  • Ford Model: Focus 1.8 Zetec
  • Year: 2009
Posted 04 October 2014 - 02:56 PM
I thought I should register so I could say thanks for the guide. My 59-plate Zetec has this issue and I have been able to use the screwdriver trick to open the bonnet to replace a bulb. I don't seem able to get it to click back into place permanently so maybe a trip to the garage will still be required, but this is a lot better than not being able to get in at all.
Thanks for the help
Stephen
#119 troy45
troy45
  • 1,301 posts
  • Name: Troy
  • Ford Model: Focus ST
Posted 04 October 2014 - 05:37 PM
If you can get the bonnet up the latch/cable mechanism can be fixed by removing the latch and cable mechanism from the car then snip the corners off the small plastic joining piece which mates with the latch, then tapping it back in. Trimming the corners off the plastic piece helps it go back into the latch easier, these usually need closing up for the piece to engage which is why you can't fix it all in situ if the cable pops out.
Had to do this on my car long time back when I'd removed the front grille slightly unevenly. It had re-engaged with the lock barrel without me noticing and pulled the cable away when the grille came off. Luckily I was at an ST specialist garage (Profile Automotive) at the time and Gary there showed me exactly what to do :)
#120 Micro
Micro
  • 303 posts
  • Name: T
  • Ford Model: Focus Zetec 1.6
Posted 09 October 2014 - 06:09 PM
Damn Feck !Removed! Drink!
Opened my bonnet this afternoon with the idea to look where I can route my new front parking sensor unit + sensor, didn't open easily (lots of key turning) and it finally popped.
I have no idea if i've hit a pot hole and the white key had jumped out, but my god what a lot of swearing and resisting the urge to chuck it across the room. Removed the whole lock assembly from the car took 2 hours to get it back in (Squeezing the two little catches on the lock mech, then quickly refitting the collar to it), and carefully refitting to the car. Dreading having to remove the front grill again to actually fit the parking sensors!
Ta for the information and pics in the first post, very helpful!
Not what you're looking for?
9 user(s) are reading this topic
0 members, 9 guests, 0 anonymous users
