m27 Posted August 11, 2012 Share Posted August 11, 2012 Hi All, The screw holding the door latch for my drivers side has come a little loose, and I can see it move slightly when opening and closing the door. DOes anyone know what type of screw or screw bit I need to tighten it? Is it a Torx security screw? Thanks Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted August 11, 2012 Share Posted August 11, 2012 I believe it's either a T26 or a T28 torx. Quote Link to comment Share on other sites More sharing options...
m27 Posted August 13, 2012 Author Share Posted August 13, 2012 thanks but i''ve tried a T30 and its too small, i'm worried it might the the ribe/polydrive screw type? Want to make sure I get the right ones before I order a screw bit set Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted August 13, 2012 Share Posted August 13, 2012 Definitely a torx. Just get a cheap bit set from a tool store. Quote Link to comment Share on other sites More sharing options...
stef123 Posted August 13, 2012 Share Posted August 13, 2012 It's a 'standard' torx fitting. Have you tried a t40 if a t30 is too small? There are a few variations of torx screws, security ( with a pin in the middle) and torx plus which looks very similar - not too common though. Quote Link to comment Share on other sites More sharing options...
m27 Posted August 15, 2012 Author Share Posted August 15, 2012 thanks will order a cheap torx bit set and see, I dont have anything larger than t30 at the moment Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted August 15, 2012 Share Posted August 15, 2012 Wickes usually do a set with various security and torx heads for not a lot of money. Quote Link to comment Share on other sites More sharing options...
