Air Con
9 replies to this topic
#1 BSH
BSH
    Newbie
  • Pip
  • 8 posts
  • Name: Stephen
  • Ford Model: Focus
  • Year: 2011
Posted 13 August 2012 - 08:28 PM
I have a 2010 model 1.6tdci Focus and i need to know the quantity of r134a refrigerant for an air con regas.
I know that there should be a plate or sticker under the bonnet showing the amount in weight to put in but i cannot find anything on mine.
I think it is 600 grams but i would be very grateful if someone could confirm this .
Steve
#2 artscot79
artscot79
  • PipPipPipPipPip
  • 5,341 posts
  • Name: arthur
  • Year: 2006
Posted 14 August 2012 - 07:19 AM
it will be in the handbook and if you plan to dont refill youreself if thats why you need it most garages will do it automatically from there database its 6oog but theres also oil to be added and deducted from the total grams depending on the oil in the system which is why it should be drained then refilled
#3 BSH
BSH
    Newbie
  • Pip
  • 8 posts
  • Name: Stephen
  • Ford Model: Focus
  • Year: 2011
Posted 14 August 2012 - 08:31 PM
Thanks , I have looked in the handbook and cannot find any mention of amount of refrigerant.
I am regassing it as we have a air con machine at work,it says 600grams on our machine but I just wanted to double check the amount.
I was hoping someone may have a sticker under their bonnet as mine seems to be missing or extremely well hidden.
Steve
#4 artscot79
artscot79
  • PipPipPipPipPip
  • 5,341 posts
  • Name: arthur
  • Year: 2006
Posted 15 August 2012 - 09:13 AM
ill have a look on mine and put it up for you okay its 0.600kg refridgerant +/-0.012kg oil WSH-M1C231-B
hopefully thats of some use to you mate
#5 Aboyner
Aboyner
  • 51 posts
  • Name: Aaron
  • Ford Model: Focus
  • Year: 2005
Posted 15 August 2012 - 02:05 PM
My air con dosnt seem to work... When I have the cold air pressed on and the switch air con on it seems the exact same temp. I may have to get this fixed but don't trust fast fit to do it and don't want to get robbed from ford!
#6 artscot79
artscot79
  • PipPipPipPipPip
  • 5,341 posts
  • Name: arthur
  • Year: 2006
Posted 15 August 2012 - 02:54 PM
ford service and refill the aircon for £69 up my way as for kwik fit etc its just a machine they only connect high and low pressure pipes thats it
#7 Stoney871
Stoney871
    Resident Lawman
  • Super Mod
  • 8,449 posts
  • Name: Clive
  • Year: 2007
Posted 15 August 2012 - 08:09 PM
Your refrigerant needs refilling.
Even if the button is pushed, if the pressure is low the aircon pump clutch won't engage.
#8 yellowpurple
yellowpurple
    Newbie
  • Pip
  • 4 posts
  • Name: Stewart
  • Ford Model: Focus CL TDDi
  • Year: 2002
Posted 16 August 2012 - 06:37 PM
Does anyone know of a company that supplies new air con pipes? I had my condenser replaced and then found that one of the pipes had rotted through so I still don't have cold air! Ford can't identify the pipe as it is the old bolt on type not the later quick release type. My car is an 02 tddi.
#9 Stoney871
Stoney871
    Resident Lawman
  • Super Mod
  • 8,449 posts
  • Name: Clive
  • Year: 2007
Posted 16 August 2012 - 06:44 PM
Any of these any use?
http://www.ebay.co.u...=item45f9e8840f
http://www.ebay.co.u...=item4abacbb3a3
http://www.ebay.co.u...=item231c29b714
#10 yellowpurple
yellowpurple
    Newbie
  • Pip
  • 4 posts
  • Name: Stewart
  • Year: 2002
Posted 17 August 2012 - 08:41 AM
Thanks for that Stoney. I was hoping to avoid used parts if at all possible (cost depending really), but I may well have to go down that route.
