Steering problem
12 replies to this topic
#1 rodgerk
rodgerk
    Newbie
  • New Member
  • Pip
  • 1 posts
  • Ford Model: Escort GTI
Posted 18 February 2009 - 05:27 PM
I've got a 1977 Escort GTI. Recently the steering seems to have developed a mind of its own. I keep getting little wobbles as if the front wheels are following the bumps and dips in the road. Also, when I change gear I get a slight pull to the right. I know I will have to get this seen to, but does anyone have an idea what may be the cause?
Have something to contribute?
#2 mintalkin
mintalkin
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 3,560 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 19 February 2009 - 03:52 PM
first i would check all the rubber bushes on the suspension and antiroll bar for any signs of play.
#3 vinnyvangough
vinnyvangough
  • 2,325 posts
  • Name: Steve
  • Ford Model: 2003 Focus TDCi, Escort Mk6 RS2000, Mk2
  • Year: 2003
Posted 19 February 2009 - 08:19 PM
Its most probably your lower arm bushes.
You can have these changed but i found it easier to change the whole arm. It is a bit of a sod but worth doing. I changed mine on monday as i had this problem too.
#4 gazwhite
gazwhite
    Newbie
  • New Member
  • Pip
  • 2 posts
  • Ford Model: mk6 1.8si
Posted 12 March 2009 - 04:52 AM
I think i may have the same problem.
How much would this cost to get done?
#5 bungle318
bungle318
    Newbie
  • New Member
  • Pip
  • 7 posts
  • Ford Model: escort gti estate
Posted 12 March 2009 - 09:39 PM
i also seem to have this problem, but my lower arms seem to be fairly new with no play
#6 bungle318
bungle318
    Newbie
  • New Member
  • Pip
  • 7 posts
Posted 15 March 2009 - 05:44 PM
changed mine today and it has sorted it, turned out there was some play in the rubber bushes. quite an easy job :rolleyes:
#7 gazwhite
gazwhite
    Newbie
  • New Member
  • Pip
  • 2 posts
Posted 24 March 2009 - 11:46 PM
I had this problem with my escort 1.8si. I have just had my wishbones changed at that seems to have sorted it. hope this helps
#8 vinnyvangough
vinnyvangough
  • 2,325 posts
  • Name: Steve
  • Year: 2003
Posted 25 March 2009 - 11:36 AM
Its only around 25-35 per arm so well worth doing it.
#9 bungle318
bungle318
    Newbie
  • New Member
  • Pip
  • 7 posts
Posted 25 March 2009 - 07:47 PM
got mine for 18.25 each from my local factors
#10 bungle318
bungle318
    Newbie
  • New Member
  • Pip
  • 7 posts
Posted 26 March 2009 - 10:13 PM
why???????
dont know what you mean?
#11 vinnyvangough
vinnyvangough
  • 2,325 posts
  • Name: Steve
  • Year: 2003
Posted 26 March 2009 - 10:22 PM
Not to worry mate, spammer
#12 blamberton
blamberton
    Newbie
  • New Member
  • Pip
  • 1 posts
Posted 07 April 2009 - 10:08 PM
i had this problem last year with ma gti except it was pullin to the left, a got the wishbone replaced and that sorted it :D
#13 kobie24
kobie24
    Newbie
  • New Member
  • Pip
  • 1 posts
  • Ford Model: Escort GTi
Posted 16 April 2009 - 09:37 AM
Hi guys, has anyone got a guide to changing the bushes on an Escort GTi. My steering is pulling (I think both ways) quite violently, usually when i'm doing high speeds. I had the same problem about 18 months ago & the bushes sorted it but was done at a garage. I'm a novice so need something fairly stagihtforard to follow. Cheers, Chris.
Not what you're looking for?
