AdBlock Warning
KitschQueen
Bit of advice needed for the unsavvy me!
Hey all I'm not a KA owner just yet but am hoping to be! I'm currently in the process of trying to find one and thought I'd found a brilliant one at a reasonable price but after looking at it's past MOT it has a number of advisories which mean not much to me. Basically I was wondering if anyone could have a look at them and tell me how much repairs might cost or whether it would be better to avoid the car altogether... :unsure:
Brake pedal has slight side movement indicating a worn pedal bearing or pivot
Nearside Front floor Suspension component mounting prescribed area is corroded but not considered excessive
Offside Front floor Suspension component mounting prescribed area is corroded but not considered excessive
Nearside Rear Suspension component mounting prescribed area is corroded but not considered excessive
Offside Rear Suspension component mounting prescribed area is corroded but not considered excessive
Nearside Front Suspension arm rubber bush deteriorated but not resulting in excessive movement
Offside Front Macpherson strut has slight movement at the upper attachment
Both outer sills corroded
This is on a 2001 KA Collection, any help would be greatly appreciated as I'm not very knowledgeable with cars and don't really have anyone to help me. Thanks in advance. x
personally i would walk away. sounds like its got alot of corrosion underneath its skin!! could be a very expensive purchase as its going to need a fair amount of welding very shortly.
Id save the cash and find a better one.
Have to agree i'd walk away too.
So far its only light work but i can forsee a lot of welding needed at a later stage. Rust is very rarely on the surface underneath a car. There is usually a lot more going on underneath what you see.
ster clear of this one if i were you
as previously said.
there are lots on the market so take your time & have a good look around.
a little rust is normal on most ka's & cars in general.
when it's the mounts that's got advisary notices on them then that will ring alarm bells to me
happy hunting
of coarse you can always phone the mot test center that done the mot to ask them about it
A lot of wise advice here.
Definitely walk away, there's plenty of good deals around at the moment.
Check out Autotrader and your local adverts--sometimes a bargain can be right under your nose!!!
