In case this is of interest to other owners, I've cracked the problem at least one way by myself.
I used one of these:
http://www.amazon.co...l/dp/B003Y3M4N6No reason to suppose any other hard drives won't work in exactly the same way, and obviously where you buy one from is entirely up to you.
This drive is 1000 GB so takes my entire music / audiobook collection and then some.
The key thing here is not to use a "standard" format because windows will almost certainly decide you want either a 32GB partition or to format in NTFS, neither of which is what you want. I used windows administration - storage management to create a partition taking the whole 1000GB of disk space and to *Not* format the drive (it'll only do NTFS from within XP, dunno about win7 but I betcha it'll be the same. I then used EASEUS partition master (9.something) to format the full partition in FAT32, with default cluster, etc.
Having done that Windows is now happy that I have a new hard disk called "Music" as my T: drive and I can create folders containing various albums and so forth from my various data stores on my network.
The resulting drive can then be plugged in, using a normal USB - microUSB lead, to the aux socket in the glovebox where the hard drive is also sitting and when I now go into AUX and select USB there are my files and folders ready to play. Limited experiments confirm I can navigate the folders and play both MP3 and .WAV audio formats with no problems, no doubt there are limitations like how many levels of folders can nest and maximum filesize would be 4GB per file because of the FAT32 but all this is fine by me.
If you hit problems with a drive drawing more current than the socket can provide, which shouldn't happen but, then some drives come with a Y cable containing the USB data/power socket and a further power socket for a second USB port to beef up the current, in this case you'd simply use an adapter in the cigar lighter socket for that second lead. Wasn't necessary with this particular product. My audio system is the SD card based touchscreen navigation model which is in the second half of the navigation manual ford have on the website at the minute for 2012 models, if this matters for compatibility and stuff.
Latest Comments
More
