Front Screen Wash
#1
Posted 20 February 2009 - 05:11 PM
#2
Posted 20 February 2009 - 05:28 PM
The front screenwash isn't working. One jet stopped then the other jet after a few days. I can hear the pump working. The rear screenwash works perfectly. The bottle is full.
Clean the jet washer with a pin. It is probably blocked.
#3
Posted 20 February 2009 - 08:35 PM
the only thing i can think of is the nossle is blocked try clearing it with a pin also put some screen wash liquid in it
#4
Posted 21 February 2009 - 09:35 AM
#5
Posted 01 March 2009 - 11:21 AM
Would have thought the obvious thing to do would be to take the pipe off from the nozzel under the bonnet, squirt the washer and get someone to see if water comes out the pipe! If so the jets blocked, if not then either the filter in the bottle is blocked or the pipes come off at the bottle.
#6
Posted 01 March 2009 - 06:37 PM
Would have to agree. If it isn't a blocked jet its most likely the bit gauze in the washer bottle behind the pump. Common problem in the fords unfortunatly.
