Hazard Lights Stuck Flashing
4 replies to this topic
#1 James Bedding
James Bedding
    Newbie
  • New Member
  • Pip
  • 2 posts
  • Name: James
  • Ford Model: Focus TDCI Zetec
  • Year: 2002
Posted 01 September 2012 - 10:22 PM
Hi all,
The other day i started up my 2002 TDCI Focus and the hazard lights started flashing on their own. Pressing the button didnt stop it, however hitting it did. This made me think it was the switch that was faulty, which was then disconnected.
A couple of days after this the hazard lights started flashing again and the RAC came out to inspect it. They unplugged the alarm control unit which stopped them flashing and recommened i bought a new one, saying it was definatly something to do with the alarm. It has been left unplugged which now means i have no indicators or central locking.
I was just wondering if anyone has any experience with this sort of problem and whether it is something to do with the alarm control unit or a fault somewhere else?
Thanks,
James
Have something to contribute?
#2 STEADS
STEADS
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 1,132 posts
  • Name: NEIL
  • Ford Model: FOCUS 1.8 TDCI TITANIUM AND 2.0 TDCI
  • Year: 2009
Posted 02 September 2012 - 05:43 PM
I,d go for a faulty hazard warning switch first had this problem once on a clio and its the least expensive
#3 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 21,274 posts
  • Name: James
  • Year: 2007
Posted 03 September 2012 - 01:20 PM
agreed, the disabling the alarm unit will just be coincidence, as the two are linked it probably broke the circuit and thats what stopped it.
Start by replacing the switch, and check all the earth points, have you noticed any other electrical gremlins?
#4 Dan62
Dan62
  • 537 posts
  • Ford Model: Fiesta
Posted 03 September 2012 - 03:26 PM
Hi all,
Thanks,
James
It sounds like the wire between the switch and the control unit (TCU GEM) is shorting to the car body.
Removing the switch you probably moved the loom enough to stop the flashing and after driving again its moved back to where it was.
Removing the switch eliminates it from being the problem, for those suggesting a new switch.
I would advise you to check a wiring diagram for your year and model, the hazzard switch should be shown as a single pole normally open switch with one side of the switch going to the control unit and the other side grounded.
Ifs probably going to be a Black/Orange wire you'll be looking for.
D.
#5 James Bedding
James Bedding
    Newbie
  • New Member
  • Pip
  • 2 posts
  • Name: James
  • Year: 2002
Posted 06 September 2012 - 10:54 AM
Cheers for the advice !
Had a friend have a look who tried replacing the relay which seems to of worked. Fingers crossed it stays that way!
Not what you're looking for?
