Help - Mot Failure - Save Or Scrap ?
focus brake pipes discs
12 replies to this topic
#1 yoz
yoz
    Newbie
  • New Member
  • Pip
  • 2 posts
  • Ford Model: focus 1.6 zetec
Posted 04 September 2012 - 08:45 AM
Hi all ,
this is my first post here and i wondered if any of you can help me with a question or two ?
I have a 2001 1.6 Focus Zetec which has just failed it's MOT , and failed miserably !
It has full service history up till last year , mainly main dealer and 73,000 on the clock , anyway my question is - scrap or repair ?
it needs ( there's a lot ) -
nearside front brake disc is seriously weakened
offside front brake disc is seriously weakened
offside front brake binding
offside rear brake binding
brake pedal creeps down
offside front track rod end ball joint has excessive play
front brakes imbalanced
offside front brake pipe leaking **dangerous**
all brake pipes excessively corroded , fronts , rears , front to rears at rear
and a new tyre
My local garage said it would be "way over £500" and that i might need the brake calipers done too and that would be another £200 or so . Does the price sound fair and is it worth doing ? the bodywork and interior are in good condition , seems that's all that is !
Have something to contribute?
#2 MrRedman
MrRedman
  • Budding Enthusiast
  • 87 posts
  • Name: Paul
  • Ford Model: focus 2002
  • Year: 2002
Posted 04 September 2012 - 01:07 PM
Id shop around somebody will do it cheaper surely,seems a shame if everything else is ok.?
#3 stef123
stef123
  • Management
  • 5,756 posts
  • Name: Stef
  • Ford Model: Mondeo ST TDCI
  • Year: 2006
Posted 04 September 2012 - 01:47 PM
I'd defo save it, most of the work relates to the front brakes so should clear most of those defects once the pipes, hoses, calipers and pads/disc are changed.
Would be willing to help you out in fife?
#4 Stoney871
Stoney871
    Resident Peacekeeper
  • Super Mod
  • 17,805 posts
  • Name: Clive
  • Year: 2015
Posted 04 September 2012 - 02:10 PM
Most of the cost is labour.
Get your own parts and and a Haynes manual.
Just be sure to get the brakes tested afterwards.
You can buy brake sets for far less on eBay and track rod ends are a half hour job and a quick tracking alignment test.
#5 STEADS
STEADS
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 1,108 posts
  • Name: NEIL
  • Ford Model: FOCUS 1.8 TDCI TITANIUM AND 2.0 TDCI
  • Year: 2009
Posted 04 September 2012 - 06:10 PM
Do it your self if you can youll do the lot for under 200 front pads and discs around £60 ish calipers more than likely just need gently squeezing back as it sounds like they have travelled nearly full distance brake pedal will come back up with new pads and is going down because of leak in pipe you can get your brake pipes made up at any decent motor factor just remove the old ones and take them with you track rod end about £15 and your tyre depends what you buy all do able below 200 so i,d say worth doing
#6 NorthSussex
NorthSussex
  • 976 posts
  • Name: Stormin
  • Year: 2009
Posted 04 September 2012 - 07:08 PM
Save it, better the devil you know; unless you are planning on getting a much newer car; too many horror stories on older cars bought from dealers that cost sheds full of money to put right.
#7 jimrex
jimrex
  • 580 posts
  • Name: James
  • Ford Model: 2011 Mk3 Focus, 2009 Mk7 Fiesta
  • Year: 2011
Posted 04 September 2012 - 07:20 PM
I've taxed worse ;)
#8 yoz
yoz
    Newbie
  • New Member
  • Pip
  • 2 posts
Posted 04 September 2012 - 07:56 PM
Thanks everyone for your replies , glad you all think i should save it , was what i'd wanted to do , just didn't know if it was worth it .
#9 Stoney871
Stoney871
  • Super Mod
  • 17,805 posts
  • Name: Clive
  • Year: 2015
Posted 04 September 2012 - 09:54 PM
If it was major bodywork or engine rebuilds then that would warrant a scrapping but if it's just brakes and track rods then stick with.
BTW, i've definitely owned worse.
#10 tommy1340millar
tommy1340millar
  • Members via FB
  • 50 posts
  • Name: tommy
  • Ford Model: focus 1.8 tdci ghia estate
  • Year: 2005
Posted 05 September 2012 - 01:48 PM
Get that offer of help from your fellow fifer, and go to Dalgety bay, buy a roll of kunifer and a bunch of ends.
Ebay is great for track rod end, discs and pads. (and a brake pipe flaring tool)
With you doing the donkey work and someone who knows what they're doing, even with stuck discs you'll get it all done in a big day.
#11 stef123
stef123
  • Management
  • 5,756 posts
  • Name: Stef
  • Year: 2006
Posted 05 September 2012 - 02:25 PM
Dalgety bay? Clarik engineering supplies? they have moved to Rosyth now - thats where i buy all my brake pipe, fittings, exhaust clamps etc
If the OP does decide to go down the road of repairing and wants help then fair do's. i use a sykes pickavant flaremaster 2 flaring tool, makes very consistent flares on kunifer and steel (so money saved there for OP)
#12 artscot79
artscot79
  • PipPipPipPipPip
  • 7,891 posts
  • Name: arthur
  • Year: 2006
Posted 05 September 2012 - 06:33 PM
really if you minus the brakes it doesnt need much done mate ive fixed far worse if i wasnt doing 7day shifts id give you guys a hand as stef said he can help you out
#13 james_60
james_60
  • 993 posts
  • Name: Jamie
  • Ford Model: 2013 Focus Titanium X 1.6TDCI 115BHP
  • Year: 2013
Posted 05 September 2012 - 09:37 PM
I would repair it as well.
Once the brakes are sorted there are just a few other wear and tear parts to do.
go for it
Jamie
Not what you're looking for?
