Focus Mark 1 Coolant Loss
3 replies to this topic
#1 GrayWilko
GrayWilko
    Newbie
  • New Member
  • Pip
  • 2 posts
  • Ford Model: Foucs Mark 1 2003
Posted 04 September 2012 - 10:56 AM
My partner's Focus mark 1 (2003) coolant level is dropping in the expansion tank despite numerous toppings up. A pressure test has found no problems and the expansion tank cap and a dodgy hose clip have been replaced. The drop in coolant level seems to happen when the car is parked for a few days. When driving, the coolant level seems to stay constant. There are no visible signs of leakage. Short of replacing all the hoses, has anyone any suggestions please? Also, is it important to use the correct Ford coolant? I'm just wondering if other coolants will damage the hoses/seals?
Have something to contribute?
#2 artscot79
artscot79
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 7,892 posts
  • Name: arthur
  • Year: 2006
Posted 04 September 2012 - 06:10 PM
strange the loss is usualy the other way round and happens after a drive well if it passed a pressure test then id look at the thermostat housing they get brittle and leak any tell tale signs would be where it drips onto the gearbox bell housing the water pump may be on its way out and coolant will drip out the seep hole any decent garage should have checked these. how much does the coolant go down by
#3 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,674 posts
  • Name: James
  • Year: 2007
Posted 06 September 2012 - 02:35 PM
as you have already changed the cap, I would say it sounds like there is a break in a hose, once the engine gets hot, it expands and opens the hole. Check all the hoses for any watermarks that might give away its hiding place.
You never find any puddles near where you have parked after you have got your car nice and hot?
#4 GrayWilko
GrayWilko
    Newbie
  • New Member
  • Pip
  • 2 posts
Posted 11 September 2012 - 11:25 AM
Thanks lads. Problem has now been diagnosed as the water pump which is now being replaced.
Thanks for all you help
Not what you're looking for?
