Becca! Posted February 20, 2009 Share Posted February 20, 2009 Hi All, i have a 1999 T-reg ford ka. Car runs fine but the airbag light flashes so i'm a bit worried! I have read other aritcles with the same problem. some mention a lose connection with a yellow wire but i can't find it? I have also tried counting the flashes but they don't seem to be in a pattern (flashes once every 4 seconds or so) if any body can tell me what it may be please do and if it is a costly job :( Thanks again! Quote Link to comment Share on other sites More sharing options...
SierraYankee99 Posted February 21, 2009 Share Posted February 21, 2009 Theres a block connector under both front seats for the pre tensioners. Odds on one of these has come loose. They should be yellow. Quote Link to comment Share on other sites More sharing options...
Becca! Posted February 21, 2009 Author Share Posted February 21, 2009 i've tried locating these but still cant see them i'm not sure where i'm ment to look should i have the seat taken out? Quote Link to comment Share on other sites More sharing options...
SierraYankee99 Posted February 21, 2009 Share Posted February 21, 2009 No, just look under the seat and theres some wires that go into a multiplug. They work loose when the seats are moved. Common fault across the ford range. Quote Link to comment Share on other sites More sharing options...
