Couple Of Small Mods Carried Out
Carbon Fibre LED
61 replies to this topic
#46 Brigante
Brigante
    Resident Ranter
  • 2,099 posts
  • Name: Charlie
  • Year: 2005
Posted 17 September 2012 - 01:15 PM
pics of those led repeaters now for the next idea lol
I still wanna get these but I'm gonna do the wing mirror repeaters instead
#47 artscot79
artscot79
  • PipPipPipPipPip
  • 5,324 posts
  • Name: arthur
  • Year: 2006
Posted 17 September 2012 - 01:59 PM
i was going to do the wing mirrors but cant be bothered too much expense for such a small mod tried to get the st mirrors breakers want 150 quid sod that these are bright enough
#48 Brigante
Brigante
    Resident Ranter
  • 2,099 posts
  • Name: Charlie
  • Year: 2005
Posted 17 September 2012 - 02:21 PM
Lol i know but i'm gonna do it anyway. Either get st mirrors or just get the repeaters n the covers to go on my existing mirrors.
#49 artscot79
artscot79
  • PipPipPipPipPip
  • 5,324 posts
  • Name: arthur
  • Year: 2006
Posted 17 September 2012 - 02:32 PM
when i was looking i found these http://www.ebay.co.u...=item2c67ed3bed
http://www.ebay.co.u...=item3a6b1d0652
or retrofit these http://www.ebay.co.u...=item35befa2f5c
#50 Brigante
Brigante
    Resident Ranter
  • 2,099 posts
  • Name: Charlie
  • Year: 2005
Posted 17 September 2012 - 03:12 PM
Gonna do the mk2 mirror repeaters mate not the 2.5. Like off a cmax ghia or a mk2 st
#51 Stoney871
Stoney871
    Resident Lawman
  • Super Mod
  • 8,368 posts
  • Name: Clive
  • Year: 2007
Posted 24 October 2012 - 06:49 AM
Got my pedal covers on last night, a bit of a fiddle getting the clips bent tight enough but look far better than bare rubber and a plastic accelerator pedal.
#52 StanH
StanH
  • 147 posts
  • Ford Model: Focus Ghia 1.6 Petrol
  • Year: 2006
Posted 24 October 2012 - 09:05 AM
You've got me interested in upgrading my footwell lights but I am stuck.
My lights appear to be ordinary torch-type little bulbs and i cannot figure how to remove them to see what sort of socket exists to see if the ones mentioned earlier would be a direct replacement
Any help please?
#53 StanH
StanH
  • 147 posts
  • Year: 2006
Posted 24 October 2012 - 11:42 AM
Have discovered that my bulbs are little two pin capsules - how do I go about fitting LEDs?
#54 Lenny
    Resident Sherpa
  • 5,320 posts
Posted 24 October 2012 - 12:04 PM
The bulbs are T10 fitment W5W is the type of glass bulb that they are because they give out 5watts of light power.
The T10 socket is used for the reg plate illumination aswell as front parking bulbs and footwells.
For the footwell's any type of T10 led bulbs will operate.
But for the parking bulbs and reg plate bulbs; "CanBus T10" are required.
Led bulbs differ from standard halogen type in the scence that they are fixed polarity.
This means that the led will only illuminate when the current is flowing in a fixed direction. Basiclly switch on the power and insert the T10 led bulb, if it doest illuminate then pull it out and rotate it 180 degreese and re-insert it will illuminate the second time.
#55 Brigante
Brigante
    Resident Ranter
  • 2,099 posts
  • Name: Charlie
  • Year: 2005
Posted 24 October 2012 - 12:42 PM
Pedals lookin good mate. Loads better
#56 k13r4n
k13r4n
    Serial Poster
  • 478 posts
  • Name: kieran
  • Ford Model: Focus Titanium
Posted 24 October 2012 - 02:13 PM
Clive you signature picture looks good is this an led ring around your badge ?
#57 Stoney871
Stoney871
    Resident Lawman
  • Super Mod
  • 8,368 posts
  • Name: Clive
  • Year: 2007
Posted 24 October 2012 - 02:28 PM
Definitely :D
#58 Stoney871
Stoney871
    Resident Lawman
  • Super Mod
  • 8,368 posts
  • Name: Clive
  • Year: 2007
Posted 24 October 2012 - 02:30 PM
It is indeed mate.
#59 Paddy H
Paddy H
  • 389 posts
  • Name: Patrick
  • Ford Model: Focus MK 2.5 Zetec S 1.6
  • Year: 2009
Posted 24 October 2012 - 02:52 PM
Clive car looks great, was it easy removing the bottom silver clip on the steering wheel, this is the one bit I'm worried of snapping while removing.
#60 Stoney871
Stoney871
    Resident Lawman
  • Super Mod
  • 8,368 posts
  • Name: Clive
  • Year: 2007
Posted 24 October 2012 - 03:02 PM
The bottom one was easy, the front part is C shaped with a tube which goes through the wheel.
The rear bit is pretty much flat with a pin that goes through to the front.
To remove easily you need to prise the front part away from the rear part (the front bit has a lip that hooks over the rear bit) using your nails or a couple of blade screwdrivers and pull straight forwards.
The side ones clip in but also sit slightly under the airbag cover.
Lift from the outer edge and pull from under the cover.
When re-fitting you will set the horn off guaranteed so be prepared to make someone jump out of their skin.
