Mk6 Fiesta Remote Central Locking
central locking
23 replies to this topic
#1 paulwilson1
paulwilson1
    Newbie
  • Pip
  • 1 posts
  • Ford Model: Fiesta mk6
Posted 10 September 2012 - 04:41 PM
Hi, I'm after fitting an aftermarket RCL to my girlfriends Fiesta. It has central locking at the moment but the drivers door doesn't work with it (suspect it's the solenoid on that side). Would fitting an aftermarket remote system fix the drivers door issue? Am I best getting this type http://www.ebay.co.u...2#ht_500wt_1361 or this one http://www.ebay.co.u...#ht_1855wt_1111
Thanks.
#2 Richbaker22
Richbaker22
  • 32 posts
  • Ford Model: Mk6 fiesta
Posted 01 February 2013 - 12:14 PM
Hi I have the same problem on my mk6 fiesta the drivers door will not unlock with the key so I have to keep going to the passenger side to unlock it I have just brought a hawk remote central locking system on eBay and am in the process of trying to fit it did this fix the drivers door issue? And any tips for fitting as the manual I have it looks like a nightmare!
Thanks rich
#3 Richbaker22
Richbaker22
  • 32 posts
Posted 02 February 2013 - 12:46 PM
Bump ... Any help on this? Got it all fitted its gets power and I get the indicators going when I push the buttons on the remote So I know I got the 12v + the indicator and ground wires right. but the doors don't lock or unlock I know it's negative locking and I tapped into the black/orange wire in the green plug for locking and The black/green wire in the grey plug for unlocking and the blue wire for the ground, but nothing still I've also Reyes grounding it on the chassis but still nothing any help would be great
#4 rulie
rulie
    Newbie
  • Pip
  • 9 posts
  • Ford Model: fiesta mk6
Posted 02 February 2013 - 03:05 PM
i am having the same problem not got the indicators working but ready to connect the lock and unlock wires on the gem unit!! it has took me longer looking on the net for the answer than doing the job! can you reply here if you find the answer it is really bugging me now? it is a job that has took me two years to get round to and now i am stuck! i have fit the same kit to a mk3 golf and my mazda bongo no problems but this gem unit is baffling me
#5 Richbaker22
Richbaker22
  • 32 posts
Posted 02 February 2013 - 06:20 PM
On the gem unit the lock / unlock wires are the black/orange wire going into the green plug on the gem and the black/green thin wire in the grey plug on the gem (the same grey plug as the 2 blue / blue red indicator wires) this is what I got told from the people I purchased the system from and I have checked and I think they are right but I'm still not getting the doors to lock or unlock!! Ahahh you need to test the voltage on the 2 wires I have said above one should show 12v when the doors are locked and then show nothing when the door is unlocked and the other do the opposite I have tested these wires and hooked the system up to them but its still not working but from testing them its pretty safe to say these are the lock and unlock wires
#6 rulie
rulie
    Newbie
  • Pip
  • 9 posts
Posted 02 February 2013 - 07:33 PM
did they tell you if it was negative or positive trigger? basically it is a relay i have connected both n/o contacts to ground and then the commons go to the locking and unlocking wire that is if it is negative switched. i could just do with the wiring diagram of the car and i could work it out myself but there is nothing i have looked for hours.
#7 rulie
rulie
    Newbie
  • Pip
  • 9 posts
Posted 02 February 2013 - 07:45 PM
also i am going from memory cos it is dark but there is 2/3 thin black orange wires and one thicker wire is it the thicker wire? not sure on the other plug but i have also read that somewhere and tried it but it did not work but i tried the thin wires on mine
#8 sambooka
sambooka
    Sam Oglesby
  • 895 posts
  • Name: sam
  • Ford Model: mk7 fiesta tdci zetec s
  • Year: 2011
Posted 02 February 2013 - 08:10 PM
Easiest way is someone with a haynes manual I can take you a pick of the mk7 diagram for the central locking cant imagine they are much different if it helps
#9 sambooka
sambooka
    Sam Oglesby
  • 895 posts
  • Name: sam
  • Year: 2011
Posted 02 February 2013 - 08:17 PM
Top and bottom apply to front doors drivers side is the at the bottom of the diagram and the passenger side at the top of the diagram
This is for the mk7 and may differ to yours
#10 Richbaker22
Richbaker22
  • 32 posts
Posted 02 February 2013 - 11:49 PM
Yea it is definatly negative if you look at the top of the gem all the wires are in little bundles going into 5 separate plugs at the top of the gem and the plugs are different colours there should only be 1 black and orange wire going into the green plug (thats the lock wire) and 1 thinner black and green wire going to the grey plug (the first plug) thats the unlock wirehope this helps! Pretty sure mine is sorted now just got to tidy it all up tomorrow
#11 rulie
rulie
    Newbie
  • Pip
  • 9 posts
Posted 03 February 2013 - 10:01 AM
Got it all working cheers! Just wondered if you got the boot popper to open i put my meter on and it does not have a 12v on one side so did not want to connect it up incas it put 12v on it and popped a fuse
#12 Richbaker22
Richbaker22
  • 32 posts
Posted 03 February 2013 - 01:07 PM
Ahahh Mine is still not sorted went up today tinkered with what i was 90% sure was wrong and still not working I think it's the locks that must be nakered that's the only thing I can think as its all wired up properly can I have your email address rulie and ill send you a few photos to see if anything is done differently
#13 rulie
rulie
    Newbie
  • Pip
  • 9 posts
Posted 03 February 2013 - 01:19 PM
Rulie@live.co.uk just used the scotch lock wire connectors to connecting in mine was playing up at first it kept opening the doors straight away and the light for door open was on but it was a dodgy connection
#14 Richbaker22
Richbaker22
  • 32 posts
Posted 03 February 2013 - 01:20 PM
Also where did you take the 12v power supply from because I read on another forum that that made a difference I took it from 1 of the 3 thick red wires under the dash I just picked one and snipped
#15 Richbaker22
Richbaker22
  • 32 posts
Posted 03 February 2013 - 01:22 PM
Ah thanks ill go and get a few pics now and email them over I had to use connector blocks on mine not ideal but the wires were abit small for the crimps I had its driving me mad now
