daggsy Posted September 13, 2012 Share Posted September 13, 2012 Hi, im praying someone on here can help me with my ford mondeo ( reg etc is in the title) The problem started about 3 weeks ago, Driving home the car suddenly cut out, it started again straight way ran for about 10 minutes or so and again just cut out. The car is not going in to limp home mode, it just cuts out as tho you have turned it off with the key. The AA took it to a diesel fuel injecton engineers they couldnt fix the problem but this is what they said.... All systems check pump pressure ok Injector back leak checked ok Tried a new regulator valve no defferance Fitted a new fuel filter Possible electrial fault So then took the car to an auto electrian and the only fault that came back was a fuel pressure fault, but accordiing to the first garage the fuel pump has been checked and its fine. They advised to take the car to a ford garage. It then got took to a ford main dealer, and they came back and said it was fuel pump is worn and the injectors are worn, both of these have been checked and also was said to be fine by the first garage. The ford garage is saying its going to cost around the £2000 mark to fix it. but im not convinced about what there saying. Any ideas to what the problem could be would be greatly apperciated. Many thanks Les Quote Link to comment Share on other sites More sharing options...
mintalkin Posted September 13, 2012 Share Posted September 13, 2012 have the cam and crank sensors been checked, a fault with one or the other will cause the car to cut out, Quote Link to comment Share on other sites More sharing options...
daggsy Posted September 13, 2012 Author Share Posted September 13, 2012 as far as we know the ford garage didnt check them, we will get them checked asap and let you know. thanks Quote Link to comment Share on other sites More sharing options...
tazzman600 Posted September 13, 2012 Share Posted September 13, 2012 Hi there. Re your cutting out. You've had various tests done and nothing found. Try unplugging your MAF sensor and see how you go. I'm no expert or mechanic but my experiance of such a problem was simply cured with a new MAF sensor and as suggested by many then MG ZT owners who had similar probs. Good luck. If it does turn out to be the MAF then look up Tuning-Diesels, they're cheaper than a new MAF. Quote Link to comment Share on other sites More sharing options...
Shaun77 Posted September 26, 2012 Share Posted September 26, 2012 Hi mate having the same sort of problem if you come up with a cure for yours can you let me know thanks shaun77 Quote Link to comment Share on other sites More sharing options...
