AdBlock Warning
Magenta
Rear Coat Hooks Etc.
5 posts in this topic
Does anyone know how to remove the rear coat hooks ? I assumed that the small insert was just a cover for the screw but when I eventually carefully pulled it out, trying not to mark it, it's a push-in insert thing. Also, out of curiosity, does anyone know what the two small slots in the trim are for below the rear 'quarterlight windows ? I don't know if it makes any difference but mine is a five-door.
Remove the trim cover/centre peg, and rotate the coat hook 90 degrees.
The small holes in the trim are to poke the metal bit of rear seat belts into when the seats are folded down, so that the belts don't get trapped behind the seats when you put them back up.
Thanks, I would never have thought of that !
I bet not a lot of people know that - I certainly didn't ! Thanks, I've been getting the seat belt trapped nearly every time.
